Originally Posted by
Fluid
That motor will work in an AM SprintCat, depending on its use. Highly experienced oval racers have used a similar size and Kv motor in that hull, but on 10S it is marginal even for them - things get hot fast. Unless you only want to run for less than two minutes, I recommend that either the motor Kv or voltage should be reduced. There is nothing worse than to try to tune a overpowered boat and burn up expensive equipment while learning how to run it.
What do do you want to do with the boat: Oval race, General sport running, SAW-type running? Run time expectations? Type of water: ocean or large lake, calm pond, windy pond, river?
