A few questions on a FASTech.
I have a mostly stock FASTech. It has a 60A Seaking ESC v1 in it and my Spektrum Rx.
The plan is to put in a 642 prop from Egneg, and was wondering if the ESC will handle it? Stock motor, I have 2x 2S 5000mAh and 2x 2S 3800mAh batts in series.
Next, I read that the brass insert in the stock prop will make the Octura prop fit, but it seems pretty fixed in there - do I just whack it out, or grind away the plastic prop? Can I buy the brass bushings anywhere?
I have bent the turn fins, as posted here. Other than that is there any other recommendations for a new guy?
Jason
