I was lucky enough to be there today to see this beautiful boat screaming across the lake Great job Ryan!
Thanks boys. I'm going to try and pull the log data off the ESC tonight and see what kind of RPM and Amp readings I got.
wow impressive, you put a ton of work into that hull.
What glue did u use ?
This was one of my first builds. At the time I was using JB Weld for things like motor and servo mounts. I used 30min epoxy and chopped carbon fiber in the tips and for the deck stringers. Now I use mostly West Marine G-Flex epoxy thickened with silica powder
