Just my two cents, I would go off what WheelMan was getting at but slot the trim tab mounts rather than the hull holes. Just leaves you less bodywork to address later before paint! :beerchug:
Question/Concern here for anyone willing to answer.
Given that stuffing tubes are sealed around where they enter the hull, they're no longer movable, meaning your stinger angle is set/non adjustable from there on. Are people just going through that much rework when needing to adjust the angle of the stinger (removing the stuffing tube, rebending, and reinstalling/sealing)? Or is this not commonly something that has to be adjusted on a new build during setup? From what I've read, I've been led to believe stinger angle is a critical factor in building a properly running boat. Do I have the wrong understanding of this?
The stinger height is definitely set by the stuffing tube and where it exists the transom, but that does not limit the adjustability of the trim angle. The stuffing tube is usually cut flush with the transom when running a stinger. Assuming you're running a teflon liner, that can exit past the end of the stuffing tube and into the stinger, stopping before the point where the flex cable transitions into the solid prop shaft. The flex cable and teflon liner are free to flex up and down as the stinger trim angle gets adjusted. On one recent build, I cut a small piece of brass tube, about 1/2" long and installed that in the rear of the stinger tube to help support the teflon liner and keep it lined up. I had plenty of room for the prop shaft inside the stinger to not come in contact with the teflon. Some setups might not workout like that.
Just an FYI, there is another build method referred to as a "wet well". A much larger hole is cut in the transom and a tube roughly 3x the diameter of your stuffing tube is installed. That tube only runs a short distance inside the hull, maybe 3-5" depending on the size of the hull. It's capped on the inside of the hull and open at the transom. The stuffing tube passes through the interior cap and out through the rear open end. This allows a significant amount of height adjustment for the driveline since the stuffing tube is no longer anchored at the transom and free to bend from the point where it passes through the water proof, interior cap. It's most often used with a strut setup.
Ah, ok. This is what I was missing. My stinger takes in about 3/4" worth of the stuffing tube, so that is where I was seeing that the stinger angle was locked in once the stuffing tube was installed, lined up with the motor. I had not considered cutting the stuffing tube between the outside surface of the transom and the stinger. But I will be doing that now. I am however, not running a teflon liner. I went with 1/4" flex cable and 5/16" stuffing tube, no liner. My stinger does have an o-ring that seals off the space between the stinger and the transom though, so I assume a split in my stuffing tube in that area shouldn't be a problem? I will basically just cut my stuffing tube at the outside surface of the transom, and install the cutoff piece into the stinger. Will probably be a 1/8" or so gap between the two pieces of stuffing tube. This will allow my stinger to be adjustable then. Thanks again for the help!
For sake of keeping water out of the stuffing tube and washing away your grease, you might investigate how mush stuffing tube you can have protrude past the transom, and possibly still into the stinger, while allowing full trim adjustment. Obviously, 3/4" is locking the stinger in place, but there might be a compromised length somewhere. Hard to say without seeing it first hand. As you're messing with it, be sure to watching for rubbing or binding.
First run is in the books! Took it out Sunday for a test run. Decided I needed to get a feel for where the CG should really be, by actually running it, before locking in the batteries' locations. Glad I did too, because I learned a lot from the experience.
Had to pull it in off the water twice before actually getting the first run in, but each time was for silly mistakes. First time was due to a connection to the servo not being plugged in, so had no steering. Second time was due to not having the ESC parameters correct. But after correcting those little issues, she was off and running.
I believe the maiden voyage was a huge success. Especially given that this was my first boat build. I was very happy with the boat's handling and performance. And the electronics were all very happy. A solid 10 minutes worth of water time total. Two 5-6 minute sessions, with a couple minutes in between where I brought it in to check on temps and move batteries to new location for testing/learning purposes. All that and the Motor & ESC never even got warm. By the end of the second run, the lipos were warm to the touch, but nowhere near approaching hot, and no swelling. I was actually very surprised by all of this.
I did end up running it almost the entire session with a larger prop. Very glad I grabbed that before this. My original 62mm stainless prop was indeed too small, or so I felt anyways. So those of you that warned me, thank you for that, as that is why I made sure to have a larger one on hand. The larger prop is a 70mm 1.4 pitch, and I think the boat ran very well on it.
The only "issue" I noticed with the build, is my stuffing tube was quite hot by the end of the session. Too hot to touch with my fingers, but not hot enough to discolor the tube or flex shaft, or damage the epoxy around it. Pretty confident this is not normal though. So I need to figure out what the issue is there. Based on how I know the flex shaft fits the stuffing tube, and knowing the amount of grease I put in it before this run, I am a bit surprised it got so hot. Especially considering I'm not running super high rpms (I'm well within the recommended range). At this point I can only speculate that possibly the curve in my stuffing tube is not gradual enough. I've done some internet searching on hot stuffing tubes, but have not come up with much for results. Maybe some of you can shed some light on this for me. My stuffing tube is 5/16", the required size by SpeedMaster and OSE for the 1/4" stinger strut I am using. And I know my motor lines up as perfectly as I could get it with the stuffing tube, as the flex shaft goes directly into the coupler on the motor with no help, when fed through the tube up into it. So I know there's no misalignment there.
https://youtu.be/Ga663YyQAMo . Attachment 166853
Even though you have the specified stuffing tube size, there is not that much clearance between the flex and tube for grease, hence the tube heating up. This is increased with the longer run times. I use the next size up with a short piece of 5/16" in the motor end to support the flex, but with such a short shaft it is probably not necessary. The other issue is that the heat is a result of friction, which is wasted power. The other option is to go to a teflon liner and oil (chainsaw bar oil) on the flex.Quote:
After the stuffing tube heat issues last fall during my maiden run, I decided to cut out my original 5/16" tube, and go with a larger one that uses a teflon liner. After getting this swap finished, I feel 100% better about it. There's better clearance between the flex shaft and the teflon liner than there was with the 5/16" tube, and less resistance when I spin it by hand. Wish I had gone this route in the first place. Live and learn though.
Also, as I try my best to promote new stuff and stay on the leading edge for my followers and customers, I am swapping up from the LMT 3080 (6 wind), to the newest addition in the Lehner line up, the 30100 (5 wind).
Lastly, the hull is currently out for paint, hopefully complete next week. Trying to get her ready for spring!
Attachment 168176 Attachment 168181 Attachment 168177 Attachment 168179
Haven't updated this thread much, but a lot of work has been done behind the scenes, and she is ready for the water again. Just in time too, as the temperature is rising by the day here in IL. Should have some video in the coming weeks (I hope). But until then, a few photos to share with any of you following the build.
The paint has some unique metal flake in it that's more like slivers of metal rather than flakes, which change all different colors in the sun. The black graphics are all custom cut vinyl I did myself, with a cnc vinyl cutter, some knife-less tape, and a little computer time.
This boat has been built 100% in house, minus the basic exterior hull shape and the paint. Everything else I've fabricated myself.
Placed an order with Mark over at Dinogy Lipos for some larger (16,000mah) packs better suited to this beast. But until those arrive, I will get a few runs in with the MaxAmps I originally planned to use.
Time to hit the water, hope you all enjoy the photos!
Attachment 168452 Attachment 168453 Attachment 168454 Attachment 168455 Attachment 168456
Few more pics, to show the metal flake, and the tow rig (Kraken KV5TT) that's also in the build process. Next up is the custom trailer!
Attachment 168457 Attachment 168458 Attachment 168459 Attachment 168460 Attachment 168461
I bet that metal flake really pops in the sun. Nice work on the vinyl. That new motor is a beast!
That is one good looking boat. Very inspiring. I AM a fan.
Looks fantastic man! I am a huge fan of large monos. Did you manage to hit or exceed your speed goal with your setup?
Thanks guys, I appreciate the compliments!
I do no know about my speed goal. I have not pushed the boat full throttle yet, as I need to get a few more sessions in on the water to get the battery placement figured out. As of now I've just had the packs stuck in the hull with velcro, as temporary mounting, to learn what placement is best for weight distribution before making permanent battery mounts. This being the case, I'm not comfortable going full speed with the boat in case it were to get out of control and knock the packs loose from their velcro.
Anyways, I got a little video the other day, after it's first time out on the water this year, with all the changes. As I said, no full throttle yet. (Pretty sure I need to move the packs forward a little)
https://www.youtube.com/watch?v=qZ91nb-X-wE&feature=youtu.be&fbclid=IwAR3M1knJtreZYYIc3rKar WqjFcAjnCz2L0iOjwpCf ILEwZtQ2iFTlRCAtFY
Took the first onboard video a couple days ago.
https://youtu.be/_ollNHpw73s
looking great!!!
Had this thing out on the water a few times since my last post, with all this good weather we've been having. I've played around with a few different props. Taken some more videos. All in all, this boat is a blast, and I'm very happy with the results so far. Not too bad I don't think, for a first time boat build, and for the size it is.
My original prop for this build was a 1.4 pitch 62mm 3 blade. I quickly found out it was not enough prop for the boat. I bumped up to a 1.4 pitch 70mm 3 blade, which did better, but I still thought it needed more. I then went up to a 1.4 pitch 74mm 3 blade. This prop did much better than the 62 of course, but I still wasn't satisfied with it, as it was starting to run toward the hot side, and the cavitation on launch was bad. It just didn't seem to perform out of the hole like I expected it to with that massive powerplant, and I knew I couldn't go bigger on the prop. After some thinking, I remembered learning something interesting about 3 blade vs 2 blade performance on a much smaller single prop mono I have. I found on that little boat that 3 blade props could not match out of the hole performance of 2 blade props. The 3 bladers would cavitate horribly, and create more heat in the electronics. So I decided to give a 1.6 pitch 70mm 2 blade prop a try on this big Outerlimits, and boy did it come alive! I think I've landed real close to the perfect prop for this boat. Acceleration is much better, the electronics are happy, and I've met/exceeded my speed goal, as you can see from the photo below.
I have some cool video I'm working on putting together for a new YouTube upload. So stay tuned :)
Attachment 169687
Glad you found the sweet spot. 2 blades are more efficient than 3 blades, and it doesn't seem to be causing you torque roll issues with the diameter you're running.
Yeah I've been pleasantly surprised and very pleased with the lack of torque roll. During the build it seemed that many, including myself, thought it might suffer from that. However, I only notice it a tiny bit on hard, fast, full throttle launches. Maybe the large size and weight of the hull, combined with my battery placement being toward the outer edges, helps keep torque roll under control? Regardless, whatever it is that's keeping it in check, I'm very happy with it. I do think I will move the batteries forward a little. I believe it will benefit from shifting some weight forward just a touch more.
Anyways, I got my previously mentioned video compilation uploaded last night. Check it out. Hope you all enjoy. It was a fun couple of days running it on the river.
https://www.youtube.com/watch?v=Rg9XKxvAQvw
That is a great looking boat you have there and you did a real nice job on the build.
If you don't mind me asking how much did it cost to build for parts? I am thinking about changing some of my gas boats to electric because of the noise factor and was wondering the cost difference. What kind of run times are you getting?
Thank you, very much appreciated.
As far as cost into parts only directly related to it being electric, I'd say there's roughly $2,700 in it. That would be the LMT 30100 motor, MGM 40063 Controller, MaxAmps Batteries, custom motor mount by Peter Zicha (punisher_67 on here), motor collet/coupler, 8mm bullet connectors, and some miscellaneous hardware.
Whoa! Thanks for the info. I guess electric isn't very cheap compared to gas parts!
Electric setups certainly do not have to be this expensive. They can be done for a fraction of that cost, with other brand components. About 70% of that $2,700 is for the motor and ESC I chose to use. There are much much cheaper alternatives out there, if you desire to keep the cost low, which still perform very well and have good reputations. My point being, do not use my build as an example of what electric boat setups cost. This is near the top end of the scale.
Ok, thanks for the info. I will look into some options then! Keep up the great work with your boat!
Travis,
Really love this build and thinking about doing on myself. Can you send me a list of the brands and part numbers for the hardware you used? Also, who do I need to talk to to get on of those motor mounts?
Franz
Post #52 gives you most of your answers.
Finished up the boat, before it headed off to it's new owner. Had no plans of selling it, but a regular customer of mine just had to have it, so I couldn't turn him down. I can (and will) build another, so stay tuned!
Anyways, as I said, I finished it up, getting the permanent battery mounts in. I learned a lot of lessons, do's and don'ts, etc with this build, which I will use to improve upon the next one.
A few photos below for those interested. And big thanks to those who followed along, gave advice, helped with parts, etc. Very much appreciated! This build was a blast, and I am excited to start another large mono build!
Attachment 170334 Attachment 170333 Attachment 170335
Trays turned out very nice. Can't wait to see the next one.
Thank you, I was happy with them. They're nothing fancy, but they turned out good, and work great.
Regarding the new build, something I've been pondering, but haven't found much info on yet: with a twin drive setup, or even single for that matter, can the rudder be ahead of the prop(s) or does it need to be behind (not directly, just further rearward) of the prop(s)? I've started collecting parts for the next build, and the length of the stingers + props gets out there a ways and am curious if I can use a rudder with a shorter arm that places it in front of the props vs using a super long arm to get the rudder out behind the props. I have no knowledge of the effects of placing it in front, just seems I have not seen it done. Seems the rudder is always behind the prop(s). Figure there must be a reason for this, but of course am questioning if its possible maybe everyone does it that way because they're all just following a trend, or if there's a real functional reason for it. Anyone with some knowledge on this, or experience, would be greatly appreciated.
