thank you again.i wanted to ask you what you think of this list of parts I think im going to order shortly and see if I am getting the correct materials please.
motor =leopard 2845 39a 800 watt max
motor mount to fit the above stated motor
strut=speedmaster sport 20
flex cable=assembled .150 flex with a 3/16 prop shaft 2.25 long
stuffing tube=1/4 inch tube with Teflon
I want to get these parts first and get them fitted into the hull and make sure everything will fit and work properly before I re paint the hull.then after im finished with the repairs and installing the motor and drive assemblies I can order the rest of the componets to complete the boat.if you see anything I should change let me know or if you have any other suggestions I would appreciate it.thanks again.
