We are down to our last two mini ECO's. both are yellow. We will sell for our cost and include free shipping for BOTH for $300. Normal price is $189 for one with free shipping.
www.minicatracingusa.com
What is the length of the mini ecos?
I know this is an old post, I'm looking into getting a mini eco 2007 and can't find specs.
Feature:
-ARTR (Almost Ready To Run)
-For control using 2 functions
-With 1 brushless electric motor
-The model is ready for operation once the receiver and the drive battery have been installed
-RC functions
Right/left
Forward, with proportional control
-Material:Glass Fiber
-Size:430*170mm
Including:
-Mini ECO Hull
-Brushless 4 Pole Motor VZ1515
-BX40-ST BRUSHLESS Electronic Controller
-Servo
-Prop
-All other parts assembled
Excluding:
-Battery
-Radio (receiver and transmitter)
Great thanks!
Looking to order one overseas from ecomaster.torgg.
Do you know if this is a reputable site? Would a 3300kv 2845 leopard motor on 3s be a good motor for this boat?
That motor may be too big. not sure. Here is the motor that is used in the mini eco
Tenshock 4 Pole Brushless Motor VZ1515
Features
1.CNC machined AL casing
2.Efficiency 4-Pole 6 Slots brushless motor
3.High purity copper windings making maximizes conductivity
4.Powerful sintered neodymium magnet
5.High torque and light weight
6.Swallow tail rotor
7.High grade bearing
Details
Poles: 4 Diameter: 29mm Length: 33mm
?Shaft: 4mm Length shaft: 14mm Weight: 85 g
Max. RPM: 65.000 Max. temp: 180 ?C Timing: 8-10
Mounting hole distance: 19mm Mounting hole size: M3*4
Not sure about that russian company. Tenshock is very honest and reliable. You could order directly from them.
http://www.tenshock.com/tenshock-min...r-pan-731.html
What kv is that tenshock motor?
You really would be better to deal directly with Tenshock. They are the manufacturer of the boat. by the time you start adding other things to it you won't gain any speed or reliability and will spend more money! TRUST ME.
Attachment 174501
They only have the artr model, I would like to either get a hull or atleast have to install the motor and ESC. I have extra parts to use up.
email them at sales1@tenshock.com they would probably sell you a hull. They are off until February 8th for Chinese New Years holiday.
Oh ok, I'll give it a whirl. Thanks
Great..any idea how much shipping was?
