Originally Posted by
NativePaul
I have a couple of questions and an idea about this ESC.
The chamfered edges of the ESC case compared to the previous rounded edges makes me believe that they have switched from a molded plastic case to a machined alloy case, is this correct?
They say the XLX2 is fully potted so I doubt anyone has removed the case, but has anyone seen prototype XLX2 power board/s naked? Or othewise know if it has a single or dual power board, and if it/they are single or double sided.
All the previous Castle ESCs I have seen have had FETs on both sides of the board, if that is the case with this one and a good potting compound was used we should be able to mount our water cooling solutions to the bottom of the case (maybe more neatly as there appears to be screw holes for mounting there already) without the cooling suffering too much which would remove the need to break/machine off the fins on top, and if we were to leave the air cooling solution on top, we may well even see better cooling than with the current top mounted water cooling, with much less effort, and an ESC that can easily be returned to stock.
