Looks good Larry!! Simple too!
That looks great Larry!!!!
Had some fun last weekend with 75mph set-ups! We didn't run side by side, so I made a split screen. Setups are very different, but we are very close in speed. Lot's of fun. My motor was cool to the touch, but I'm not sure it will be a good heat race set-up because of the ESC current draw and temps. We'll see...
https://www.youtube.com/watch?v=C3QdasTj7eg
Ours was a bust. Too many amps and too much weight. Nice experiment though.
Looks fast! What setup were you running to reach those speeds?
I'm running the Castle 240 ESC. Concerned about current draw for the yellow and blue setups though (see graph attached).
Green - 1515-1Y w/H5 (66mph)
Red - TP4050 w/H5 (71mph)
Yellow and Blue - TP4050 w/1814 (76mph)
Was that 4s? 6s? Which TP4050? It looks like there is a lot of kv options for that motor. Thanks!
haha Pete might not want to share the kv. It's a one of a kind.
The blue boat was running a 5650 2300kv. Also a one of a kind. It is NOT a good setup. Fast enough but it's just way too much weight for the footprint. The only up side to that setup was that you could likely run it right up/through/across a guys rooster tail with no risk of blowing it over. I think if we ever stuffed it though we might never see it again. Torpedo to the lake bed.
No secrets here! The motor is a custom wind (Y) 2300KV. It's fast as snot, but I wouldn't recommend it just yet. I'm sticking with the 1515-1Y for heat racing until I'm comfortable with the current draw.....unless of course you can get ahold of an ESC that can handle it! :) Then, go for it! The hull seems to be stable at 75 judging by the videos above. Race water is a different story though. Anyone can stay upright in clean water.
That was about how we felt with the 5650 Pete. Like.....meh. It works but it's still a bad setup. Your setup was better but I get that it was tic toasty for your liking.
I'll throw that fat hog on 6s in the Wildthing and see if we can get near the SAW record.
The motor was cool enough to hold my fingers on the end bell. It was the current that bothers me. With the 1814 (76mph), it was averaging 225amps w/spikes at 300amps! With the H5 (71mph), it was averaging in the 180's. Still a bit much, but a more realistic.
You might reach escape velocity if you run that 5650 on 6S! :) I'd like to see it.
Hi guys. Just a brief update. Ran some additional testing last weekend w/2400KV motor and H5 prop. I think this is a more realistic set-up, but it still pulls some serious current (avg 200amps). The motor is cool, but the ESC was pushing 165deg after 6 laps. GPS was 71mph.
Oh....and here's the GPS from the previous runs in the videos above. Man, those were hot laps!!! Fun stuff!! Had multiple readings over 75mph, but this reading was the highest.:w00t:
Going to be cutting more kits soon for winter builds.
Hey all BP2017 racers! I built a low-profile hatch cover for this hull bought from and built by Pete, and would love to build more for the other versions as well. Would there be any interest in these for the 2017 version? If there is I can mold this one and start working on the others as well.
Experienced BP2017 racers: Any thoughts on how this will perform aerodynamically?
Mike, I would be interested a new hatch for my BP P sport hydro, I have the big brother of your LSH.
Pete, is that the version I ripped in half or is it the version I'm building?
That canopy will make for a kick a$$ runner. My opinion only.
Looks like one of mine. I've made some crazy looking canopies so maybe that's not such a good thing.
I truly believe that with this boat it matters where the slope of the cockpit lands. Opinions vary for sure and I've absolutely seen some "holy crap!" fast Pearls with the factory canopy.
I plan to make a fresh version for the new boat I'm working on. Head full of ideas with NO time.
I agree. I was very happy with performance last year as the boat really seemed to 'float' and was really resistant to blowing off. This may be due to the new "H-350" type cowl cockpit or possibly the new hull profile, but it's yet to be proven. One thing for sure, it was fun to drive and speeds were 70mph in oval trim. There's nothing like being right on the edge of blowing and having it keep recovering.
Mike, with that profile and the canopy you've put on it you should be able to detect when it's trying to blow over and just set it back down. I thought it was near perfect but Pete just keeeeeeppps fiddling. haha The one I saw ran pretty well. I'm building a 95% right now.
Thanks Terry!
Just one strip of very thin glass and west systems in each joint (anywhere two pieces come together at 90deg) will considerably stiffen the hull. I use a fabric wheel and cut tiny strips, then dab a brush in epoxy, pick up the strip, and paint in place. It goes pretty quick.
Lightweight, thin glass is the key. It forms nicely into corners.
Excellent, thank you!
This is worth the time. Especially at the front of the tub. Ahead of the batteries. Weak point on both a Pearl and an ML. It's where Ty's boat finally failed. Took multiple seasons but the belly finally broke free and puked it's innards. Some old timey nitro maz say it's unnecessary but a sport 20 sized hull travels about 7mph slower in a 2 lap trial and weighs quite a bit less.
Interesting tidbit. In a perfect world, a boat traveling 70mph through a turn (if it didn't slide and the fin held 100%) at 40 foot radius produces 3.83G. So your 9 pound boat hangs 34.47 pounds from your turn fin. If we just say the fin lets you slide.....40%?......ish (who knows) then your turn fin and rudder are still holding 20+ pounds through a turn. Maybe.........ish? Still guessing. Just a fun mental exercise. 75mph jumps the G's up to 4.39. I'm likely the only tool thinking about these things.
Obviously we apex slower than 70 but that deceleration zone going in to the turn creates some crazy forces and in odd directions if you think about it. They aren't exactly square to the structure of the boat. Would be a cool stress analysis in Creo or something. Imagine trying it in a car. 40 foot radius at 70 with yer face all smashed against the glass.
Glass the joints. It's one extra step, adds almost zero weight, costs next to nothing, and the boat will hold together longer.
