My stock esc died just after 5 packs on 3s. I replaced the stock esc with a 30a esc that can handle 4s. Would the stock motor be able to handle the 4s?
might be to many rpms for the motor
Ran a 4s 850 mah batt today. It so fast compared to the 3s. It was almost boring to run 3s. Only ran it for 3 mins. Motor temp after the run was 95f and esc was around 90f. I only ran the 4s once and 3s another 7 runs back to back to torture test the esc and motor.
What ESC did you go with?
I'm using a modified 30a Hobbywing aircraft esc. Basically I took the cooling pipe off the original esc and jb weld it onto the hobbywing and re-shrink it. I also jb weld the cooling pipe that is ziptied on the motormount. Almost forgot to mention that I silicone sealed the esc.
http://i437.photobucket.com/albums/q...730_170952.jpg
Minizoom how has your 30a Hobby Wing esc been holding up on 4s? Any programing or over heating issues?
