I'm working on it.... :spy:
Looking forward to your build thread..... :wink:
A friend suggested this........
Oh Yes! Now we're talking.
https://forums.offshoreelectrics.com...6&d=1557715963
https://forums.offshoreelectrics.com...7&d=1557715975
https://forums.offshoreelectrics.com...8&d=1557715986
This hull makes these plus many other boats.
I'm in!!
After the underwhelming response on the full and complete kits I've done thus far :glare:, I’m thinking anything I do in the future should be a “Short Kit” with just the 1/16” ply bulkheads, instructions, drawings for the skins and assorted parts, and recommendations for the hardware. I may include the precision 1/16” SS tube for the 1/32” wire drive because it is rather hard to source.
Here’s what I would have to do to make that happen:
1. Buy a set of plans from Newton Marine.
2. Take them to Kinkos and get them scanned into an electronic format.
3. Import them into AutoCAD and trace them with polylines with complete dimensional precision.
4. Allow for cutting kerf on all parts.
5. Design a parts layout to minimize waste.
6. Obtain plywood.
7. Deliver plywood to laser guy.
8. Pick up cut plywood from laser guy.
9. Buy boxes.
10. Package and ship the kits.
There’s a whole lot of time, money, and work up front to make this happen and I’m already sitting on a ton of inventory. The only way I would want to do that is if I had commitments from enough people up front to make it worth my time and effort.
In my first post on this thread, and subsequent others, I talked of why I am so enamored with these smaller hulls. A lot of folks chimed in with the “loss of places to run the smaller boats…” and other excuses to avoid building one :glare:.
Hello!! You can run these little boats ALMOST ANYWHERE :doh:. Yes, I understand they don’t like wind and the waves it creates, but there’s something called: EARLY MORNING, and in some places: EARLY EVENING where the wind dies down and the water is like glass :cool:. And yes, fast moving rivers aren’t really good for these either, but there are hundreds of thousands of little ponds and lakes throughout the country where you can run these.
Big lakes that host sanctioned events could run 1/20 scale before breakfast with clever names like “Hangover Hydrofest” or “Morning Delight” :moon:. The simplicity of these little hulls and ease of transport means little to no support equipment is needed to run a few heats. All you really need is a few batteries and a roll of tape; maybe a couple of Allen wrenches and a screwdriver if you’re really hardcore.
Diegoboy really wants me to do a more modern hull, and I’m willing to do it; provided there’s enough interest to make it worth my effort. I’m not looking to make a profit on these; I just want to avoid taking a loss. I don’t mind donating my time in doing all the CAD work; it’s like playing video games for me, but plywood and laser cutting isn't cheap. It's far better to amortize the costs over several hulls to keep costs down.
So come on boys and girls, get on the 1/20 scale train where "Fast, Cheap, and Out of Control" is more than a slogan, it's a motto! :olleyes:
The smaller boats are so much fun and cheap to power and quick to charge and easy to haul and I can go on and on.
The cowl sides at the cockpit opening were pretty thin on the prototypes. I modified the production kits with thicker sides and more support on the bottom. This additional support gets sanded away at the end, but it prevents breakage during most of the shaping process. The underside of the cowl needs to be hollowed out slightly to accommodate the curvature of the deck/hatch.
So I've mounted the cowl to the deck hatch, and I'm faced with a new dilemma: What to do for the exhaust? The hatch has a narrow tape ledge all around it that should be easy to access for the convenience of taping down the hatch. On the full size boat (later named "Miss Detroit") the entire exhaust manifold was below the top of the deck and only the tailpipe stuck up above the deck. This tailpipe would be right in the middle of the tape ledge. If I had chosen to do an exposed engine hull to model, I could have used a 3-D printed motor and "fudged" the hatch and motor location to work.
I've given this a whole bunch of thought and think I have an easy solution: Forgetaboutit. The cowl will be exactly as it is in the photos other than it will be painted yellow with the Thompson Electric Co. decal on the fin and the Chuck Thompson decal on the sides. I may make a decal for the grill opening in the front of the cowl, but that's it.
Hey! It's 1/20 scale, I don't need no stinkin' exhaust...... :tt2:
UPDATE: I was just thinking....... (Uh oh... ::huh:) I wouldn't have this exhaust problem with a modern turbine hydro. Come on, show some interest; these little boats are FUN! :cool:
Attachment 165138 this is the one I am going to build pipe might work
As the epoxy is cooking off on my 1/20 Short Circuit build, and I'm waiting for the laser guy to cut motor mounts for MPR Prototype #2, I'm thinking of things to come. The order of completion of my projects is as follows:
1. Finish the Short Circuit.
2. Finish MPR Prototype #2.
3. Finish the Atlas (Screwed-up some paint).
4. Finish the Mini Outrigger.
5. Begin Secret Project X4. :spy:
#1 and #2 might be done concurrently.
and number 6 is make a video and build Manuel lol
...... So I decided to paint the cowl. Looks like I need to contact my DLP guy and have a driver printed up.....
The instrument panel will eventually have a brushed aluminum cover and the interior bottom will be painted flat black. :cool:
That is looking great Dr Jet.
Sent from my moto g(6) using Tapatalk
Thanks, Jim. :wink:
So the cowl shown in the photo above had a couple of days to dry. I shot some clear on it and the pink deck portion immediately crinkled up BIG TIME! :cursing: The yellow portion did OK, but it had a couple more days to dry.
So I sanded all the pink back down, and I'm waiting a few more days to shoot the color back on it. Then, I'll wait at least a week (maybe more) before attempting to shoot the clear coat again.
What a PITA.....
In the meantime, I'm adding some color to the hull, but again, I'm waiting a LOOOONG time between coats.
Well, I've shot some color on the hull. Now, I have to let it dry for a week or so, then wet sand some scratches and imperfections out of the deck. After that, I'll shoot a final yellow coat on the entire hull, and let it dry for a week or more. Then, I'll put the U-99 stencil on the deck and shoot the masked-off deck with pink. When dry to the touch, I'll remove the stencil and let it dry for another week. Then I'll put the black outline decal on the U-99 and let it dry for a few days (photo of my 1/16 scale Short Circuit).
Only THEN will I attempt to shoot clear on it, and in fact I may wait a while longer.
It may be done by September.... :olleyes:
I'm a bit of a perfectionist. :olleyes: As I'm sanding the hull, I see minor imperfections and say to myself: "I can shoot another coat and sand that out." I keep using higher and higher power eye-wear and see things that normal human beings won't see from a couple of feet away. I could continue that routine for the next couple of months getting it 100% perfect, but I have to remember this is a prototype and not a "showboat" or a world-class racer. :wink: So with that in mind, I may start masking off the deck for the U-numbers and start getting ready to shoot some pink on it.
Maybe I can shoot some clear on the cowl now without wrinkling the pink. :confused2::thumbup1:
You don't want to know ALL the issues I'm having, but here's one: When removing the U-number mask, some of the underlying yellow paint came with it. :cursing: No biggie though, I can spray some yellow into a container and use a brush to fill in the chips. I have to wait at least a week to shoot the clear so I'm in good shape.
Other than that, it's starting to look like Chuck's boat... :cool:
I'm going to start shooting some clear tomorrow.
Well, things are rapidly coming to a close. :sad: The Short Circuit may be ready to run by this weekend, although that will really be pushing the paint drying schedule (I shot the first coat of clear this morning). The Atlas needs a minor paint touch-up and final assembly to finish it out. The Atlas prototype is currently running and I may do some cartoon-ish paint scheme on it, just to have it fully finished. I’m thinking maybe a Batman theme or a James Bond theme to go with the Auric Enterprises scheme on my Micro Scat Cat (Auric Enterprises was Goldfinger’s phony front business for his illegal gold smuggling operation).
I’ve received a lot of views and comments on the 1/20 scale models, but little interest in actually building one, which is a shame. I’ve followed some of the other threads regarding FE, one of which is this: https://forums.offshoreelectrics.com...-in-the-future 1/20 scale solves a lot of issues brought up in that discussion. It’s cheap enough for newcomers to build something competitive for a couple hundred dollars. It’s easy to over-power the 1/20 scale models with cheap Chinese motors and 2S batteries so there really doesn’t need to be a rule limitation. The hull does that for you: Run a Neu 1112 on 3S and you no longer have a boat; you have an uncontrollable aerobatic airplane. :scared: 1/20 scale also lends itself to spec racing like the LSH of days past. Everybody runs the same motor and battery. The 1/10 scale guys do that same thing.
1/20 scale will never REPLACE the bigger boats, but it would make a great ADDITION.
With all that said, there’s always Secret Project X4……. :spy::tape:
Video of the very first run of the Short Circuit Shovelnose. There was a lot of grass in the lake and I wound up towing a lot of it around.
https://www.youtube.com/watch?v=pUECqAqElt0
Nice run! It looks great.
Why there hasn't been much activity here.......
https://www.youtube.com/watch?v=E-gf5FqXHCg
Is that you in the cockpit?
Very cool! Too scary for my taste though
Fall of 1971 [Eeek]- Wurtsboro Airport upstate New York
All I can remember is that when the towline drops off the silence is mesmerizing......
Attachment 165664
