Congrats! Good job! Do you have an air dam on it?
thanks for the add, Mr.Mad!
Hello!!! I’m planning on upgrade the motor and esc on my veles!! Any recommendations??? I have 1716 not from dasboata but from bonzi. I would like to keep my prop but I want a bigger and faster motor. Appreciate all help.
Hull and motor mount are solid on the veles;as for the motor:up to 40x82 will fit easily-additional motor support-plate recommended on the heavy ones though.
Is your veles already fine tuned and maxed out with the stock motor/esc combo?Madrcer has demonstrated more than one time of what the boat is capable if it is well prepped. Also think of runtime as your are limited on that narrow hull to use 3s in series-i once tested 2x 3800 mah 6s in parallel and that was a mess.Good luck.
4s UL-19 and "other" 3831 equipped boats
4S - Black Pearl - Spec Sport Hydro- ABC 1815-17-45
59MPH - 60MPH
Setup for racing.
In the list on the right - it says Max speed - 60MPH
I could not find it on the map.
Yeah!! I saw his videos but I want something that I don’t have to look constantly for temp. I was thinking to use TP 3640 or 3650 with 180 amp esc 2080kv or 2400 kv on 6s
O , can i use in veles 29 stock lipo 3s 6000mah 65c ?
Yes, Assuming they will fit in the battery tray. Be careful running this boat on 6s (2x3s lipos) with the stock prop will overheat your electronics. If you want to run 6s you will need an Octura x442 prop to safely do so.
ok tks, for stock set, best battery combo cells?
5s is the best option for decent speed and low heat while running the stock prop. (1)-3s pack and (1)-2 s pack of the same mAh and c rating. 5s 5,000mAh will get you around 4min of playtime.
can i use a rhino 3s 50c 5000mah as 2s 50c 5000mah nano-tech?
You could, but by them being made from different companies you could potentially have issues if one was weaker than the other. I would only recommend using the same c rated packs that have the same mAh and that are manufactured by the same company. Those 50c rated nano-tech's I believe are rated at 25-50c, meaning 50c is the max output of the pack. You need a pack that can tolerate at least a 50c discharge such as the nano tech 65-130c rated packs. This forum has a lot of threads on batteries and if you do a search I'm sure you can find answers to all your questions about batteries.
ok, thanks , what is de bigger dimension lipo i can use in veles 29?
what type issues i can have with diferent companys?
Is this page still a thing? I am a little late to the party.
I would really like to see strut setups!
Member: Nemesis17592
MPH:68MPH
Prop:Dasboata 1715
ESC: Stock
Motors: Stock
Batteries: (2) 3s REVO 70c
Attachment 169192
Attachment 169193
I added you to the front page. It's been pretty quiet on this list for a while. Nice job.
