I'm running a Leopard 40x74 on OSE outdrive in a Tunnel hull. Runs great but I do get airborne sometimes resulting in a bottom's up condition :doh: So what do you guys do to prevent corrosion inside the motor, WD40 or some other spray ?
Thanks Jake
Thanks Jake
I've been told that this works really well! https://www.offshoreelectrics.com/pr...hp?prod=corr-x
WD40 is evil, keep it away from anything electric or bearings.
Corrosion X works well, just smells weird.
I typically take the motor apart and oil the bearings, the rest I just wipe clean with alcohol.
Use boat tape and that eliminates that problem 90% of the time.
Corrosion X
Yeah, corrosion x is safe for electronics
Thanks guys, will do !
