Almost done! Still missing Dasboata's 1716 props... dang customs :swear:
New servo, dual pick up rudder and changed the cooling lines for larger ID. Also re-route the ESC's, dunno if that's better or worse. Usually you shouldn't fix anything that isn't broken...oh well.
Attachment 160475 Attachment 160476 Attachment 160477
About the gap between the drive dog and the strut. How it should be measured? Because the motors axle moves 1-2mm inside the motor and it affect the whole drive system.
I noticed quite some vibrations at the hull when tested the throttle on a bench, is it normal? Of course short period of time, just to make sure everything was working.
By the way is CRC's silicon grease good for the flex drive? It resist heat and water, and it doesn't brittle rubber/plastic.
