Originally Posted by
RC boat addict
OK I have just tried the Glitch buster and it done nothing.
I also tried a new ESC a Hobbywing Seaking 160 pro, it done nothing.
And yes I am setting the failsafe on the receiver and yes I am testing on the bench.
I am not sure what you mean by set the fail safe up in the transmitter,I turn the transmitter and the boat on and set the throtle as I turn it on, as per usual then I test the revs and then while its sitting there with no throtle, I press the fail safe button until the receiver stops flashing then I let it go.
I then rev the motor and shut off the transmitter while its revving and within a second the revs drop to nothing just like your boat.
Then whilst i am looking at the receiver flashing, because it has lost its signal, I count the flashes and on the 40th flash (40 seconds)the motor starts revving at full rpm. I turn the remote transmitter on and its stops revving. The only difference is when the boat flips in the water and it sitting upside down, it wont rev or turn the steering, (as best as I can tell because its usually not close enough to see the rudder).40 seconds later it starts revving flat out but now the prop is in the water enough for it to run wild until it burns out the motor from no cooling because the rudder scoop is out of the water or it smashes into some object like a jetty or a moored boat or the shore.
My transmitter is a Flysky Hobby King copy or re-badge.
I also have tried my other transmitter it is an Absima CR2S.V2 both do the exact same thing.
I have tried a HK GT2 RECEIVER and a FLYSKY FS-GR3E Receiver both do the same dam thing.
So I am interested in what you mean about setting the transmitter?
or If anyone has any other idea?
