Hi Does anyone have some raw ABC 1918's they would part with? I know I could call Jim but I want them like right now. I want to run my scale in oval trim this weekend and see how far my calculations are from reality.
Thanks,
Hubert
Thanks,
Hubert
Do he even make a 1918? Seems like something he would but I haven't seen that.
He makes a 1918-10-50 is that the one you after?
Hi Terry and Jim,
Is the "50" the BAR and "10" the rake? I have a motor I tuned that I think will be a good oval motor. The calculator seems to like the 1918. But I'm not positively sure of which port of that prop it likes. Maybe I should get all the available s and test each one.
https://forums.offshoreelectrics.com...5&d=1592233453
In a performance hydro with 10s lipo @ 9800 mah and a castle 240. Prop wizard selected an ABC 1918 as the most efficient prop for the setup.
Resultant:
28,221 rpm
141 amps
4,955.78 watts Pin
4,728.58 watts Pout
run time 4.15 minutes
est speed 79.20 mph or 127.46 Km/h
Eff. 95.42%
The efficiency doesn't begin to drop off till 284 amperes surely the beginning of the end @ 10.5 kW. Here are the motors constants and parameters
Rm .oo5 ohms
Kv 824
Io 3.27 amps @22.5 volts including radial fan load.
Weight 448.8 grams
12 slot 10 poles
https://forums.offshoreelectrics.com...6&d=1592234070
What a long day....:closedeyes:
Hello Chris,
Is that right for your name? Do you offer the aging service for the ABC beCu ? A few of the props i want done with a special LE backside detail . Those ill; likely do myself but I would possibly interested in a hardening service. Do you do stainless as well?
Thanks ,
Hubert
No thank you I dont want a prepared prop at this time. Andy Brown or myself does that. Im looking for raw 1918's
Regards
Hubert
Post over on intlwaters.com Mark or Walt may have them
What is the direct line to ABC and Jim S. ? I cannot find it in my contacts.
Hubert
