-MYSTIC 114CM HULL.
-4092, 2000KV MOTORS.
-42MM 45MM 48MM PROPS.
1. WHAT SIZE BATTERY CAPACITY ARE BOATS THIS SIZE RUNNING?
2. WHAT THE AVERAGE RUN-TIMES?
3. CAN BIG CAPCITY (OR PARALLEL MANY BATTERIES) WORK, WHAT ARE THE AFFECTS OF ALL THAT BATTERY WEIGHT?
4. DOUBLE OR TRIPPLE THICKNESS MOTOR-MOUNT PLATES. CAN THAT ELIMINATE THE USE OF THE REAR MOTOR MOUNTS?
Cheers,
