I need some help, I bought a new ekos P1 vee hull. I need some measurements of some of the stock hardware. The stinger length and the length of the rudder and rudder bracket. And help would be appreciated.
Joe
Joe
The stinger lenght is 1/10 of hull lenght, Speedmaster stinger strut is ok, for 3/16 propeller shafts http://www.offshoreelectrics.com/pro...os-stinger-str
This Speedmaster rudder is perfect http://www.offshoreelectrics.com/pro...prod=ose-80050
Use a 3/16" flexcable http://www.offshoreelectrics.com/pro...?prod=ose-1190
What kind of setup for this hull? 4S or 6S? I think the Venom KOS P1 must be reinforced with carbon layer
Thanks for the info
Hi,:tiphat:
Welcome to the club,
I have bin adding info to this thread so it will be easy to find later on in one place.:beerchug:
Hears some info and ideas on this boat.https://forums.offshoreelectrics.com/...-offset-rudder.
Thanks Jenny but first I have to find out what the stock distance from the transom to the leading edge of the rudder is?
Why? If you choose the correct hardware for a 35", forget this stock hardware
alfa I am in the dark on this rudder and stinger setup? Should I go with a longer or shorter rudder bracket? For a motor I am thinking of the turnigy outrunner 1600k. I also want to go with the panio wire drive, what do you think?
Piano wire is for small boats, I give you the answer : 3/16" flex and drive shaft. I don't know this Turnigy motor, consider Leopard motors, 4082 1450kV is a very good choice
Lenny thank you for the stock measurements.
Joe
Just applied another laye of fibeglass to the inside hull. Gotta let it cure fo the next couple of days. I have to add just a little more fg to the inside nose. I am going to use a thicker piece of fg to put up in the front hull to add some weight to the nose.
I put an order for a P1 KOS hull undrilled and its canopy, 150 €uros shipping to France included. I want to use a set of outrunner motors 500 class 1700kV. One 6S battery, two Seaking 120A and two FMT 3650 1700kV motors
