it def does a superb job with battery trays and anything else that doesn't need an immovable mounting.
Got her sanded up today Attachment 156844Attachment 156845
I might try a tube of the glue used to hold side car windows into their slots. That stuff is crazy. I did a window in my old*!**Pontiac and*!**that stuff was brutal to get off anything once cured. Might need to do same thing on my 02 Monte Carlo and there is always leftovers.
Yup, window urethane. Just be careful, as it’s really messy stuff, it’s a lot thicker and firmer, and may be more expensive. Also, if you ever need to remove them, good luck. That won’t be any easy job. The silicone was $10 shipped and held 6s packs mounted to the floor of my Df pirate 35 mono.
Attachment 157010Attachment 157011Attachment 157012Attachment 157013Attachment 157014Finally got some paint on.
First sealer, then base then red clear coat.
Attachment 157015Attachment 157016Couple more
Today was sunny so I got a pretty decent pic. Tonight I started trying to do the rudder linkage and mount servo, and I realize I need to move it back to the right side like I originally wanted to. I’ll get into more detail about my reasons why with my next update.
Attachment 157079
Very nice! What prep was needed on the FG cowl before primer?
Nice paint job. Looks like an old school candy paint. What did you use for the base, gold or silver or what?
Bob
i just made a quick vid instead of explaining everything in here,
https://youtu.be/5LXZyYV4xno
Attachment 157238Last evening I got the servo mount glued up with some gflex, and used the silicone ASI to glue in the radio box. Last I will need to mount an esc, but I’m not sure if I’m sticking with this motor or what esc I will be using. At any rate, this thing is nearing completion. i got the armma servo, because its red, but its a different shade of red from the paint so it looks stupid. ill probably just buy a black servo, just not sure which one.
Did you round off the corners of the non essential edges so paint would stick better on edges? Of course not the ride surfaces.
Nice work!:thumbup1:
Attachment 157432Got the window and turbine intake all painted up. Tossed a couple of starter decals on there, and got the turn fin mounted up
Looks good!
I got a 3630 2070kv I'm going to throw in my gsx when ever I get around to finishing it. I just finished a mini sniper this week awesome little hull.
Attachment 157443Attachment 157444Attachment 157445
Turn fin.
So, i cut a piece of clear vinyl and stuck that down first, then some plumbers putty around the screws and mount. the holes i drilled are tight enough to be waterproof anyways, but ya know, more precautioning.
Attachment 157446Attachment 157447Attachment 157448
Let me upload a couple of photos from painting the windshield.
Ye ah not much to it really. tape, paint, clear, pinstripe, sharpie
Boat has came out nice. Nice handy work.
When you get a chance let us get another shot of the whole boat.
What a glorious job on the paintwork. Looks brilliant.
