My Hammer has the original running gear, Brushed 550 motor, shaft...etc. Is there anything that I need to do, as far as maintenance goes, after each run? Thanks for any input.
Make sure to buy some marine grease and keep that drive shaft lubed up. There is no teflon liner inside your stuff tubing so the grease wears out after each day of running.
Thank you.
