Since both my boats are OTS at the moment, I figured I would compile this for reference. I am pretty sure some info had changed or may be incorrect but this is to start with and I can update as the info comes along. Can members on this list or in the modding thread post their MPH and props here and I update them? I can add a metric for Mods such as motors, esc, etc. For those missing props on this list is because I can't confirm if it was stock or another prop. Let me know and I'll add them. The list is in no particular order unless you guys want me to sort that out by fastest?
Change (1) Clean up list
Change (2) Added Mods Section
Change (3) Added Motor, Batteries, ESC Section (17/11/16)
Change (4) Sorted by fastest MPH
Change (5) Who doesn't like a shiny trophy?? The trophy Dino Erickson has is the modded trophy (no longer stock motors or ESCs) The trophy MADRCER holds is the stock configuration trophy (ESCs & Motors remain factory) It is pretty obvious why Dino holds that coveted shiny trophy. I would of loved to get these trophies to the right side of the info for each member but the forum ain't having it.
Change (6) Must show proof. Either GPS or Data Log
Change (7) I don't check the fast list daily but I'm pretty active on the forums still. If you want me to add you, post here. If I don't within 2 days, PM me please!
MODIFIED ZELOS TWIN! (Who needs stock Motors & ESC's?)
Attachment 148188
Member: Srtdino
MPH: 95.9
Prop: Dasboata ABC 1715
ESC: Dynamite 160 from (Zelos 48)
Motors: TP4050 2100kv
Batteries: 2 x 6s Revo 70C
Member: Rafael Lopez
MPH: 93.75
Prop: ABC 1817
ESC: Castle 240
Motor: DYNS1630
Batteries: Dynamite Reaction 5000 50C 11.1v LiPos x4
Member: Keagan-Z06
MPH: 87
Prop: abc 1915 (47mm)
ESC: Seaking 180
Motor: Poseidon 1515
Batteries: (4)x Revolectrix 3S 4400
Mods: OSE Flex, Sharpened Rudder, Polish Flex.
Member: Erroneous
MPH: 86.4
Prop: Dasboata ABC1915-17-45
Mods: Sharpened rudder, Sanded Sponsons, High torque Servo
ESC: Swordfish 240
Batteries: (4) 3S Revolectrix 435 silver labels
Member:paulfromtulsa
MPH: 78.5
Prop:X447
ESC: Turnigy 180
Motor: TP3605 2080kv
Battery: (4) 3S Hobbystar 7600mAh
Member: BanixJ
MPH: 75.20
Prop: TFL CNC 4314
ESC: Stock with timing 7.5
Motors: Keda Saker SKF-3668 4 poles 2160kv 1650W
Batteries: 2x Zippy Compact 3300mAh 6s 60C
Mods: JEFF wire shafts
STOCK ZELOS TWIN (Factory setup: The way it was delivered!)
Attachment 148189
Member: MADRCER
MPH: 108
Prop: Dasboata Super Sonic
ESC: Stock
Motor: Stock
Batteries: ??
Member: MADRCER Member: MADRCER
MPH: 80.77 MPH: 90
Prop: ABC 1716-17-45 Dasboata Prop: ABC 1716-17-45 Dasboata
ESC: Stock with timing 7.5 ESC: Stock with timing 7.5
Motor: Stock Motor: Stock 3831's (Updated factory replacement motors)
Batteries: 4x3s Gens Ace 5500mAh 45c (11.1v) Batteries: 4x3s Gens Ace 5500mah 45c (11.1v)
Member: srtdino
MPH: 80.6
Prop: Dasboata 1715s
ESC: Stock
Motor: Stock
Batteries:3S Revos 5000mah
Member: GreyBolt99
MPH: 78.3
Prop: Stock
ESC: Stock
Motor: Stock
Batteries: 4 x HOOVO 3S 11.1V 5200mAh 100C Lipo Battery
Mods: None
Member: Fweasel
MPH: 77.9
Prop: Brian Buaas ABC 1715 17-45
ESC: Stock
Motor: Stock
Batteries: Revolectrix Graphene 4x3S 70C 5000mah
Member: yeeharacing
MPH: 77.5
Prop: Doctor Props 640/3 CNC
ESC: Stock
Motor: Stock (3831)
Batteries: (2) 6s Mojo Racing 70-140c 5000 mah
Mods: wohlt wire drives
Member: Kfxguy
MPH: 76.3
Prop: ABC 1814-17-45
ESC: Stock
Motor: Stock
Batteries: Revolectrix 3S 5500 (Series)
Mods: Sharpened Rudder, Polished Flex Shafts
Member: JPriami
MPH: 75.7
Prop: ABC1816/3
Member: Gohan
MPH: 75
Prop: ABC 1715 *17-45 (kfxguy prepped)
ESC: Stock
Motor: Stock
Batteries: Revolectrix GoPacks 5000mAh 3s 70C
Mods: Sharpened rudder, Polished shafts
Member:Arrover
MPH: 73.4
Prop: X447
Member: Stratus
MPH: 72
Prop: ABC 1814
ESC: Stock
Motor: Stock
Batteries: Turnigy Graphenes 65C 6000 x(4)
Member:DaHammer
MPH: 72
Prop: ABC1814
Member: Chevyprerunner
MPH:70.4
Props: Dasbota ABC 1714 17
Motor: Stock
ESC: Stock
Batteries: 2 old Turnigy Nanotech 3300 6s in parallel
Member: pistol18
MPH: 70.1
Prop: Dasboata X447
ESC: Stock
Motor: Stock
Batteries: (4) Lectron Pro 5200, 50c
Member: BanixJ
MPH: 69.61
Prop: TFL CNC 4314
Mods: Polished JEFF flex shafts
Member: REDLINE1
MPH: 69
Prop: X447's S&B&D
ESC: Stock
Motor: Stock
Batteries: Revolectrix x4
Mods: Wolt Wire Drives
Member: Ghandi32
MPH: 69
Prop: X447 S&B
ESC: Stock
Motor: Stock
Batteries: Revoelectric Graphene Oxide 5000mah 70c 3cells
Member: TeamLucas
MPH: 68
Prop: X447
ESC: Stock
Motor: Stock
Batteries: SMC 5000 mAh 50C x 4
Mods: OSE Flex
Member: vinnyp Member: vinnyp
MPH: 66.8 MPH: 79
Prop: ABC 1814-17-45 Prop: ABC 1914
ESC: Stock ESC: Stock
Motor: Stock Motor: Dynamite 3930
Batteries: SMC 7000mah 90C x4 Batteries: SMC 7400 3s X (4)
Member: Keagan-Z06
MPH: 65.5
Prop: Dasboata X447
ESC: Stock
Motor: Stock
Batteries: (2) Revos 6S 4400mAh 70C
Member: Banzee
MPH: 63.1
Prop: X447 (S&B)
Member: Sachaken
MPH: 63
Prop:
Member: mikiek
MPH: 62
Prop: CNC 45mm
ESC: Stock
Motor: Stock
Batteries: ??
Member:mercer2
MPH: 60.89
Prop:
Member: Xtremespeed
MPH: 58.7
Prop: Stock (S&B)
