Water in Hull - Impulse 26
Hello All,
Need some advise from the pro's out there on the water i'm getting ito the hull while running.
I bought this bought used but like new a few months back. Upgraded to a PB-1500 brushless with 120a ESC and a 4S 330 battery.
The boat screems but I end up with approx 6-8 oz. of water every at the end of every run. I completely taped up the hatch and submersed it to to find only a couple small bubbles from one of the trim plate screws. I removed and sealed all the fasteners and grommets, also pressure tested the cooling lines. Receiver is sealed in a balloon.
Yesterday I made two more runs with the prop shaft greased heavily and the outer hatch taped up. Still get the water......
Is this normal or acceptable ????
All can can determine is the water come up the prop shaft.................
Thanks in advance for any feedback.....
