ZTW Seal 200 amp - can not remove reverse operation - Help
I have two of these ESCs and can not program out the ability to run the boat in reverse. I have tried both a V1 and V2 programmer unit with the same results - the only difference I can see between those two is V1 has nine steps and and V2 seven omitting Sbec output voltage and Governor mode (WHY?) When trying to program these the only step I can see that MIGHT be for locking out reverse is motor rotation but no all that does is what it says - make the motor run in the other direction. I can do that by swapping a couple of wires w/o a program step. Can someone tell me what I am missing here. Or maybe there is no way to program it out ? Thank You for your help!!
