Guys if your using my props please don't keep it to yourself :buttrock:
Using his prepped Props he is referring to.
Ok I might be way off, but Dasboata makes custome props? Hench (prop X447 Dasboata)
very nice thank you ill try to get a hold of him
Dasboata...I need props :)
I'll try my best but members will have to chime in and state what Props they running, motors, batteries.
Here's my specks.
Stock esc's
Stock motors
Props x447 s/b
Batteries.2 Revoelectric graphene oxide 5000mah 70c 3cells
Sharpened Rudder
Sent from my SAMSUNG-SM-G935A using Tapatalk
List is being overhauled based on suggestions by Fweasel
I am on the list twice. Ditch the 66.6 (bad number anyway) and keep the 68 mph on stock electronics, OSE shaft, x447's and SMC 5000 50C 11.1 x 4 lipos Thanks
Yup, thanks. Just need to find some props with more pitch, which ABC doesn't make in reverse rotation. Honestly, I think I'm in the realm of cutting my own props down. The motors I am using love to rev, but can get bogged down by the wrong prop quite easily.I may cleaver some 447s and see what happens.
The fastest props so far on stock electronics is ABC 1715's on Gohan's and 1814's on mine. I went 76 and Gohan went 75.
Not sure if I have the 76 on video but here's some close
https://youtu.be/0GppLp4RZqo
https://youtu.be/N6ueY9gCIg8
https://youtu.be/_EeJHgl5p9I
Can you update mine.
Stock electronics
Revo 3s 5500 packs in series
Sharpened rudder
Polished flex shafts
Suggestion. Arrange from fastest to slowest.
Man, Keagan has some work to do.... The ABC1915s on mine are Dasboata props. Batts are 4 3s Revolectrix 435 silver labels. Havent had time to rebuild and run the Go-packs yet.
Updated fellas! This list should get some guys off their lazy boy!
Travis: I'll sort the list in due time since other members are now taking notice of it. I have some Dasboata X447s coming so my measly 60.5 should go up some.
Hey Keagan, here's my update
I got a quick run in tonight with a set of Dasboata X447 that he cut down to 45mm that I bought here on OSE.
Yellow boat ran 70.1!!!
All stock gear
Batts.... don't laugh, Qty 4 of Lectron Pro 5200, 50c
Struts are set at 4mm that Rafael suggested.
I'll try and run it again this holiday weekend and get some video if possible.
Updated! Nice job pistol! Should be getting mine today or tomorrow.
Did 65.5mph today with Dasboata x447s. The front is bouncing, I dropped it 1mm, same thing. I think gradually easing into it may help as these props seem to generate more lift than my x447s I detounged. Will make another attempt as I believe more is in her.
