Which races? I've been to a few. I've never seen a motor checked. Aquacraft motors aren't having their windings, rotors, bearings, checked. Voltage yes. Motors no.
That was part of the problem with the old rules. Couldn't be tech'd in a practical manor. Impound the boats, dissemble maybe 12 in a day, start measuring them against the manufacturers specifications to ensure that they are in fact out of the box. I promise you this has never been done.
This is the problem with anything other than a can dimension too. If we say "unmodified" how can we be sure that the stator, windings, bearings, rotor, shaft, wire cover, endbell, bearing lubrication are "as manufactured". Collect them and check against their respective web site? Some came with connectors. UN-modified implies that you can't change those either. Heck, some came with motor screws. This is what Mike was getting at. As manufactured was a disaster when it was part of the NAMBA rule and it will be the same now.
Should have left it out. Kicking myself.
ugh, remember when this was a thread about the nats?
