2 Attachment(s)
Miss Geico 36 motors left right with control via steering
Hi, yes sounds strange but this is something I wanted to try.
I'm new back and this is my first dual prop cat, I have a small place to turn in on my pond if you could call it that and turning this cat seemed strange, like it wanted to roll over, I know i should probably go faster and like "drift" it around the turn but the edges of my pond are concrete walls.
Anyway I am trying out an idea, when I turn the rudder more than about half to the right the the right motor pauses and when I turn the rudder more than about half to the left the the left motor pauses.
I still have full speed control over the operational motor, when the steering returns to close to centre the paused motor is unpaused.
I have only had 1 run and not enough practice to tell, short run as had a flip, but 1 advantage is when flipped I can use the system to help blow the boat back to shore.
What do you guys think, dumb idea or something to work on?
Regards,
Rob
Sydney Au
