Looking for suggestions on prop starting point for my boat. It is a 44" Aeromarine Avenger 44 with twin TP4070 1090kv motors on 12s. Any help would be appreciated.
Thanks.
Thanks.
Are you sure it is 12's to each motor, or 6'S to each motor ? 12'S is too high on the RPM (48,000)
What is it that to plan to do with the boat?
It's at the upper limits. Can run it for saw passes.
Stan
SAW - is two passes, one in each direction. - then bring it in slow - and let it cool down completely, recharge and try two more passes.
With your setup - this is about all you can do, without hurting something.
Fun running would be out of the question.:flashfire:
I'm new at this. So I may need to back it down to live. Lol. So 6s would be max for said combo? I have alot to learn.
with 1090 KV - 8'S to each motor would be fine for fun running.
Thank you sir!
