Better Trim Tabs & Turn Fins
stadiumyamaha advised adjusting the trim tabs down, he's right. Manual says to bust out a large set of pliers to do the job, wrong answer.
Pliers my a$$, these bolt on replacements are the right answer... http://www.offshoreelectrics.com/pro...d=ros-spdt-150 - they will make it far easier for you to get your boat dialed in correctly -- Well worth the $16 for the time & hassle they'll save you.
Look at the transom of the AQ Revolt, they come from the factory with adjustable tabs similar to the SM's - there's a reason for that:wink:
UPDATE: I found this thread after my original post, the contents say it all... https://forums.offshoreelectrics.com/...IM31-Turn-Fins!! - Using those with the SM trim tabs should make your boat handle much better.
Good luck & happy boating
Quote:
Originally Posted by
GLRE Raptor
I bought a pro boat impulse 31 v2 over the weekend. Running on two 3s 5000mah lipos.
The boat is a lot of fun but bounces alot when close to wot.
Here is a quick video.
https://www.youtube.com/watch?v=nySN...e_gdata_player
Any pointers?
Thank you
Sent from my Galaxy Nexus
