12volt 47 amp 564 watt,
24volt 47 amp 1130 watt.
I am using two in series for 24v on my lab 8, they are very stable, rock solid,
They are set up ready to go with 4mm outlets and power cords.
Heres a close up of the bussiness end of the power supply.
You can see the 24v model is wrapped in black, comes with jumper to allow 24V. as you can see you can use 2-12v and 1-24v at the same time. 2-12v top row , 24v bottom row, or remove the jumper and you have 4-12v outlets. With the jumper in place you also can use the out two far out side connections for two 24V outputs. These power supplies are rated at 47 amps. I have personally abused my test setup, just to see where the fail point is. I have had my Lab 8 with 6-5000 3S @ full 40 amp charge and a cellpro 10 with 2-5S running wide open. I'm still using this power supply with no problem. Just because I did this for testing purposes,,,,,,,,,
I DO NOT RECOMMEND GOING OVER RATED OUTPUT!!!
Singles are 12v and white $55 shipped
Doubles are 12v and 24v and black $110 shipped
These are 100% ready to use. Plug and play
I will ship out of the US,
Check out the thread on RCG
I have sold many there!
