Second Motor Mount Project
  • boredom.is.me
    • Jun 2009
    • 595
    2) Custom faceplate for 36+40mm and support for 40mm. This was one of my earlier projects. The milled out side is not completely smooth and will require a little work. However, the other side is flat. You would also have to drill and tap the side holes. I will not make side plates for these. They are 59mm wide and made from 1/4" with about 60% milled through. Again, these are not perfect. You will see what the project would have been in the picture below.
  • 78MaicoRider
    • Jun 2013
    • 179
    Although Christmas 2016 has past I hope these parts are available. I have a Bridgeport clone to make the side plates. Having these parts would save me from a lot of work on a hand crank mill.
    41" & 29" FE Aeromarine Sprint Cats, Quickdraw powered "Dollar Eater" 41" Insane Cat, 29" BL mod Graupner Cat, 24" Hydro, 29" OB Cat, BL mod NQD Tear Into Jet boat, 55" Scarab, JET SWEEP R/C pool skimmer Rescue Boat.
    • boredom.is.me
      • Jun 2009
      • 595
      No problem. PM me your address.
