Fast Electric World Championships
  • Erik Aa
    • Aug 2011
    • 80
    #31
    Thanks, Paul.
    Interesting mods. In your opinion, are these mods secondary to getting the wiredrive angle right? That is my hunch.
    Best,
    Erik
    • NativePaul
      Greased Weasel
      • 2761
      #32
      Dee was there and came second in Mono1 with the new Sirrius, David Niewland was not there. Joseph was tough to beat in the heats, but in the calmer final his unstepped Triton was a bit sticky so he was slower than he was in the heats and his cells were dumping at the end, the Belgians had plenty of speed to blitz past him on the straights and not worry about trying to get inside him on a corner.
      The stock ETTI Exiga is a great boat, very fast and good handling, the most common Mono2 at the worlds and most of them were stock, set it up right and you can have a boat that is competitive at the highest level. In flat water it is probably better than Tom's, however when the water is rough they can catch the nose on a wave and dive for the bottom so make sure you have a failsafe set and plenty of floatation inside.
      • Erik Aa
        • Aug 2011
        • 80
        #33
        Thanks, Paul. It is great that you provide us with these glimpses into the world championship.
        Do you have any pictures of the new Sirius? The only picture I've found on the web is the one promo shot.
        Best,
        Erik.
        • Gromov
          • Aug 2012
          • 49
          #34
          Hi guys.
          WC in Belgium....
          Best race, best time.....
          I got two World champion titles. In ECO MINI Expert and in FSR E. :)
          My ЕСО expert took 12th place - the boat was *damp*, a new ... tuned only to the last race ...
          It's a pity ..
          The plan had three gold medals ...
          But two - too great ...
          More vids and pics - coming soon
          ecomaster.torgg.com
          • NativePaul
            Greased Weasel
            • 2761
            #35
            Very well done Evgeniy, 73 laps in FSR-E is awesome, 6 laps ahead of the next best scores, we don't run FSR-E in England so it was the first time I had seen it, I was expecting it to be a lot slower given the (15min?) runtime, but they are pretty damned quick, I may have pics and vids too still going through them and it is taking a while as I am back to work and I took a lot. Did you see the Mini Eco Junior Team final or were you too busy preparing for your own Finals? I am usually a surface drive guy but that was one of the best and most spectacular races I have ever seen in any class.
            • Gromov
              • Aug 2012
              • 49
              #36
              Thank you for the congratulations, I'm a long time coming to this result ...
              I totally agree with Bill Ox. should have 1-3 class racing with the same rules of racing to the racers could compare the results and to become in the end - true Champions of the World.
              Now, in America - World Championship without Europe racers, in Europe -World Championship without American racers.
              Need to do something
              ecomaster.torgg.com
              • BILL OXIDEAN
                Banned
                • Sep 2008
                • 1494
                #37
                Like button : )
                • ron1950
                  • 3024
                  #38
                  so was that a 15 min race? I couldn't get the vid to work....if so. how do u get 15 min run on todays batteries?
                  • NativePaul
                    Greased Weasel
                    • 2761
                    #39
                    I agree too, it would be great to see participation from more countries even more so when they are well into FE racing like Austalia, Canada and the United States of America are, thankfully the gaps in the competition are closing up in America at least, when Randall Tripp et al came over to the worlds in 96(?) did you even have an offshore class in the states?
                    If you take a small Pltd offshore mono it might do OK in Mono2 with just a change to a legal Battery, I have switched to 3s 4500mAh but I heard that the 2s folk had 7600mAh to play with, you would need to find 2 minutes of runtime, but if you run on 2p for Pltd offshore (do you? I'm guessing you do) a Naviga legal 560 gram battery is probably under half the weight of your 5Ah highC packs (thunderpowers are under 560g, Hyperions are over 560, Gens Ace are over 560) and shaving 1-1.5lb of your boat will gain you some time as will the lower RPM the lower C packs will give you.
                    Or you could try running a Pltd rigger on a motor and prop that you would use for Pltd offshore, just the switch to a rigger may get you the extra minute you need without propping down, my JAE runs fine on small X series props even though lifters are recommended for some reason. I run a 3674 in my JAE but several people at the worlds remarked at how big it was and indeed my last motor was a 220gram Mega 22/30/2 and was well up to the task just too high KV for me, so the spec Motors should be enough and the advantagious spec motor may switch from the UL1 which is a lot lower than usual for us, to the 1500kv proboat motor, being closer to the mark for 6s 4500mAh, with props around 40mm.
                    I am interested in how they get the runtime in FSR-E too, I am not even 100% sure that it is 15 mins, it was a good bit longer than Eco standard that is 10 mins though, I think they are allowed an 840g (2lb) battery (840g could be 2s 20Ah or 9s 4500mAh) which is quite a lot for a boat that is not that big, if you compare it in his second picture to the one in his first which is a mini and will be just under 450mm(17.5") long. they look just a little bigger than eco experts, what does yours weigh all up? 1600g/3.5lb?
                    • Gromov
                      • Aug 2012
                      • 49
                      #40
                      Originally posted by ron1950
                      so was that a 15 min race? how do u get 15 min run on todays batteries?
                      22,2V 6300 mAh LiPo battery....
                      Race time 15 min, M cours 60x15 meters
                      Boat long 600 mm, weigt - 1400 grams
                      ecomaster.torgg.com
                      • NativePaul
                        Greased Weasel
                        • 2761
                        #41
                        I finally finished with the Photos from Friday's practice session, lots of interesting pits photos IN MY PICASSA ALBUM but I will update with other days photos which are mainly boats on water at a later date. There is lots more to go in there but so far there are:-
                        Pretty boats.
                        Interesting boats.
                        Many self-righting riggers.
                        And a few boats on the water.
                        • BILL OXIDEAN
                          Banned
                          • Sep 2008
                          • 1494
                          #42
                          More pics please! : )
                          • Manny
                            • Jun 2008
                            • 32
                            #43
                            Who makes the blue and white rigger ?
                            • NativePaul
                              Greased Weasel
                              • 2761
                              #44
                              Did you check out the album Bill? There 120+ so far and more mainly action shots to come, but just for you I uploaded 2 more.
                              Ted gets in on the action
                              Ted gets through scruitenering in the drivers seat, out onto the drivers stand is pictured here being held aloft by his pit man Don in front of the transponder tent, and even passes a self-righting test to make sure he wont drown, but race control would not let him drive in case he fell off as he was not wearing a lifejacket, luckily George McDonald was on hand and offered to take on the driving duties once Ted told him which way up to hold the transmitter.
                              I'm not sure who makes the blue and white one, I think it comes out of France but anything else went in one ear and out the other, it was information overload and my main interests were sponson sizes/shapesangles and methods of getting riggers selfrighting rather than who sells what.
                              • ron1950
                                • 3024
                                #45
                                just a thought but what language did you all use over there? anything other than English and id be lost for a week
