Well I'm not sure what to tell you, you'll just have to try it.
One of our employees bought an ARC and took it home over the long weekend and reported a 14.55min run time just playing around with it in choppy and windy conditions and being cautious. He ran a new 6S 25C 5000mah pack. He is a typical newcomer to big electrics so this is an example of the type of use and run times we should see. As a customer gets confident and faster with the boat things will change.
If you look at a data log graph when this boat is driven the peak amps hit at the pull of the trigger and taper off, its not a continuous high load. When you let off to turn the boat will coast so it reads nearly zero load and then the cycle starts again. So the added run time is from the fact that the load is not perfectly continuous coupled with the driving style you end up with more time than the straight math predicts.
In testing the 50C packs for sure are way better than the 25C packs but the point is the boat works fine with the least expensive packs too.
