PRO BOAT UL-19_How to run on 6S with stock prop
  • sammyha
    • Jul 2018
    • 1037
    #166
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1037
      #167
      • sammyha
        • Jul 2018
        • 1037
        #168
        • sammyha
          • Jul 2018
          • 1037
          #169
          • sammyha
            • Jul 2018
            • 1037
            #170
            • dasboata
              • Dec 2010
              • 3152
              #171
              I not trying to bust your balls and I'm not getting into a debate with you about this ,, but adding those tubs are only restricting your water intake your probable decreased your intake area by 80% and,,, 1 into 2 is still only one the rudder should have a flat bottom because it adds lift to the boat
              • sammyha
                • Jul 2018
                • 1037
                #172
                • scottyp
                  • Aug 2018
                  • 57
                  #173
                  Chris (Dasboata), I’m curious why all of these rudders, stock and upgraded, come with a taper that comes to a sharp edge on the bottom if what your saying about the bottom of the rudder needing to be flat is true? Not doubting what you’re saying, just wondering why the manufacturers wouldn’t have that as standard. Thx
                  • scottyp
                    • Aug 2018
                    • 57
                    #174
                    By the way Sam, I was actually able to drill out the three remaining nipples on my esc quite easily. The problem on the first one is that I tried to drill to deep and the bit locked and tore the nipple right off. I drilled that one out like you suggested and am now just waiting on the parts for the fix you suggested which I have a feeling is going to work. 👍
                    • sammyha
                      • Jul 2018
                      • 1037
                      #175
                      • scottyp
                        • Aug 2018
                        • 57
                        #176
                        I’ve got a few of those coming so I should have options regardless
                        • dasboata
                          • Dec 2010
                          • 3152
                          #177
                          Your going to have to ask pro boat that ????
                          • fweasel
                            master of some
                            • Jul 2016
                            • 4285
                            #178
                            Careful with drilling out the 120A Dynamite ESC cooling nipples. Don't get to aggressive on the drill bit size, even when there appears to be plenty of meat to bore out on the tip of the fitting. The narrow circumference portion is actually quite thin walled and is very easy to crack when too much material is removed. I prefer to re-tap the heat sink and install a larger diameter fitting for better flow.
                            Vac-U-Tug Jr (13mph)
                            • JJROTOGEEK
                              • Sep 2018
                              • 3
                              #179
                              Are u still digging the negative pitch on the prop????
                              • JJROTOGEEK
                                • Sep 2018
                                • 3
                                #180
                                https://youtu.be/p6Djit-7R14 handling isn’t great on 5s on. Neautral prop angle. I did have my batts to far back tho. I’m going to try the negative angle and mod the tube as u suggested
