I would be pulling down the Outboard prior to running just to ensure that everything is free from binding etc. while being a new boat it still requires pre run maintenence apart from just pulling the flex & adding grease.
Stiletto First Run w/New Boat
when i did all that to mine it had some greese in it all ready but can always use more not much to the outboard for a few screews lol and a motorMY RETIREMENT PLAN?????.....POWERBALL
74 vintage kirby clasic hydro, pursuit mono, mg, 47'' mono, popeye hydro...Comment
What about the spring-like effect when turning the prop? Would that be consider binding or it's normal?Comment
For those of you who are finding you not getting 100% throttle, try increasing the throttle travel to 150% I have done this with the motor pulled from the leg & peak revs have increased, this was my personal finding.
This is with the Dx3s & does not mean it will work with other transmitters.Comment
Lads, are you running full throtle on the bench for more than 4 seconds, if so, the motor may be toast and always check your drivetrain prior to any power input on a new setup or RTR boat
DouggieComment
Made a test run today using a 150% throttle travel setting on my DX3s. Noticable differencea. Now feels like I'm getting all the power this boat can give. More linear on the trigger from 0 to 100%. Increased speed with new setting. I would say w/o gps maybe 35mph. Very fast for this boat and easy to conrtol. Great looking boat, runs really great. I'm going to try the stock prop that I have sharpened and balanced next. You will be hard pressed to get 40mph in stock form.Comment
Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
Thanks Darin, I will try the 42 X 55 grim sharp/balanced. I have been holding back on using that prop, for fear of overheating electronics.
Yes, I was referring to stock prop. Sorry. Thanks for desiging such a great boat, I just love the Stilitto looks. Your info on setup for this boat has been right on the money. Saves everyone so much time trying to find the sweet spot. Keep the info coming!Comment
