Stiletto Race Prep
This is a sticky topic.
Yeahhhhh!!!
Stiletto Version II is on the way!!!!
Now that is the one I will get!!!
I saw GP73 taping the plastic cover and I said
And the cables from servo, I said
And swapping ESC it was
Wicked, cant wait for the reworked Stiletto to be available....DJI Drone Advanced Pilot
CanadaComment
?Where did the info come from?...LINK?Spektrum Radios
Proboat "Impulse" 31 Deep-V
Proboat "Mystic" (On the list!)Comment
I think he's just dreaming... I wouldn't hold my breath for that one for a bit. WAY too many other projects on the table at the moment.
Testing I was doing wasn't related to that part!Darin E. Jordan - Renton, WA
Spektrum Radios
Nothing at all... don't think that the same thoughts haven't crossed my mind as well! Maybe down the road. I'd LOVE to have another shot at getting that damn battery tray cover made! If Tupperware can do it, why can't we??
As for the cables... wouldn't change that, except to add cable protectors over their length, and pass those through the bulkhead to the servo. That's how it's done.Darin E. Jordan - Renton, WA
As for the cables... wouldn't change that, except to add cable protectors over their length, and pass those through the bulkhead to the servo. That's how it's done.Spektrum Radios
Here are some examples. Grim did a good job on this one....Darin E. Jordan - Renton, WA
Darin...on the bottom of the outboard the rudder seems to be very blunt and 90 degree angle into the water ...would it be beneficial to round and sharpen the bottom of the skeg below the prop ?Spektrum Radios
If I ever get the urge, I'll replace the rubber pieces by filling in the holes and then adding brass tubing that just fits over some cable covers, but for now, it works fine the way it is, and frankly, isn't worth carrying the extra weight, even if it is just a few grams.
Why are people so concerned with covering these cables??
Got everything back together tonight. Set it up with a converted Castle Phoenix ICE-100, and also some wire extensions, so I don't have to unseal the transom every time I need to swap out ESCs or replace motors. Can also use the entire length of the battery tray now for battery placement. Just laying the ESC on top of the cells, or on a foam insert, depending on where I ultimately place the cells.Attached FilesDarin E. Jordan - Renton, WA
Im not Concerned but ...when you say you would do it as an upgrade then we all figure it would be better than what we got hahahaha...We are all just tweakers at heart trying to make things perform/last a little better hahahaha......AND its Winter up here in canada the only water that isnt frozen around me is in my house ...so we are idly just looking at our boats which makes us want to work on them hahahaLast edited by lonneyb; 02-07-2011, 11:22 AM.Spektrum Radios
