I am telling you it just was ripping around our little track and then nothing?? I had truning but no motor I must have got a bad ESC from the start. This morning she running on the 120amp and should be good to go:)
Stiletto Race Prep
This is a sticky topic.
Okay the flex shaft went out. It has had a good run that was the stock one and I got a good ten runs out of it. Can you guys tell me does the water pick up tube come short like that for a reason? What they ran out of tubing? Mine goes and then stops about 3mm away from the pick up is this the way all of them are? Gettting ready to put my brass tubing and new flex shaft tubing with oiler in and might as well fix every thing since I have the case open at this time?????Comment
Guys... just so you know... in case you haven't thought of this yourselves... .150" flex cable sized Lower Units are NOT intended to be able to handle the power or RPMs that many of you are putting through them. Look at what the Nitro guys do... The 3.5 sized lowers (what you are using on your Stilettos) are using in 3.5 stock, and 3.5 Mod... These setups do NOT put the kind of power down that our FE motors do, and certainly don't have the torque. Additionally, they only turn around 30,000+/- in most cases, and have to spool up to that. They don't put down the instant power that an FE motor does. Their .45 sized motors use a .187 sized flex cable and a much beefier lower unit to handle that kind of power...
SO, if you are going to run huge props, or 5S/6S setups (6 * 3.7V/cell = 22.2V * 1800KV = 39,960RPM), then I'd expect to carry a lot of replacement flex cables around...
Those of us that race can get away with a little more because we are NOT out then starting and stopping and jumping and whatever else the sport community is doing with these, so we aren't putting the "shock" into the flex cable that you guys likely are.
The system was really designed to run a 4S sized spec-power system and be able to handle some reasonable upgrades.Darin E. Jordan - Renton, WA
"Self-proclaimed skill-less leader in the hobby."Comment
What I did with mine, is to take the lower apart, and assembled everything onto just one half. This allowed me to see where the cable was riding, etc. The holes near the coupler and the stub likely need to be opened up slightly to give the flex some clearance, and you need to make sure there is some end-to-end play in the cable as well. It should NOT be jammed all the way to the bottom of both the coupler and the stub, but rather have just a slight amount of end-to-end play in it. You can adjust this by adjusting the cable length (I use a disc grinder to sand down the ends a little at a time), and by adjusting the coupler on the shaft. Don't over torque the stub-shaft into the unit either, as this will cause excessive drag on it, and make sure your drive-dog isn't getting jammed down into the teflon washer from over-tightening the prop nut.Darin E. Jordan - Renton, WA
Hello darin I think I must have miss wrote or you miss read. I am only running the 3 cell in paraelle I don't know if that is spelled right but you know what I mean. Any way what is the trick to bending this tube? I had one almost there and then it gave way. I heated it up and on that stuff. Should I just buy a tubing bender or is there a better way that does not cost me any thing? Any tip or tricks you guys can give me would be great? ThanksComment
Hello darin I think I must have miss wrote or you miss read. I am only running the 3 cell in paraelle I don't know if that is spelled right but you know what I mean. Any way what is the trick to bending this tube? I had one almost there and then it gave way. I heated it up and on that stuff. Should I just buy a tubing bender or is there a better way that does not cost me any thing? Any tip or tricks you guys can give me would be great? ThanksDarin E. Jordan - Renton, WA
I'm still running the stock setup on the outboard, only thing I've done is remove the grub screws either side. When I grease the flex I take the motor out and pull it out from the top and refit in reverse. Haven't had any probs so far running 4s on an x640.Comment
Thanks darin and guys . I just got back from home depot and got a pretty nice bender for 12 bucks. Now I have been testing it on the tube that I jacked all up and it seems the sand or salt might work better . But I will see. I am going to take a break for now and jump back on this later. If any body else has any help or tips please let me know okay? Thank you. EricComment
Im running mine on stock motor/esc on 5s 65c thunderpower 5000's. It is quicker for sure. Using an octura x440 3 blader. I noticed...obviously the rpm is much greater. But, In my friends identical stilleto he is still running 65c 5000's but in 4s and he is using a grim racer 40x52 3 blader and his boat is setup the exact same way as mine and his is pretty much on par with mine speed wise. Mine is a hair faster. Example: drag racing down a lake i will pass him. But I noticed that if I give hime the jump mine just barely starts to reel him in all withing a couple mph by the time we hit the end. Thats about 200+yards long. Next im keeping the 5s, but gonna try the grim racer 42x55 prop to see if that gets me an edge. I love the control ya have with the 3 bladers though. Way better than a two. I also plan on trying a new octura lifter prop from my hydro. A V942/3 is going on it. I got the prop shaft all modded. Their is almost no boat in the water kinda like a hydro. Nothing but maybe 1 1" of the stern fuse and the prop in the water. Its floating on a cushion of air.I have read elseware that some swear by a lifter on an outboard and others oppose it. I myself stick with my beliefs.....seeing is believing. If the esc blows out, no biggie. I got the castle replacement right here. I just found it interesting that his boat was almost as quick as mine on virtually the same prop with one less cell. Boggles my mind. It sure as hell sounded like mine was waaaaayyy faster. But in reality it wasnt as fast as it sounded. Now wish me luck!!! Im gonna go try and smoke this esc...LOL!!Comment
