So its starting to look.good. I.think.all the blue will be off tomorrow night THEN. I will resand and clean tomorrow. I will also put a second coat.on the inside. This time I will tape the outside of the.hull. The top was very smooth with the 600 grit. Smooth.as glass. Now if I could get the finished paint to.be that smooth. Any tips. Also tips on tears and checkered. I talked to my gpa today and he has body filler and is up to the task. This should be fun. I will test after blue printing before I paint.
So are you wet sanding?Walmart has ducttape in flames bubbles and checker.I haven't done checker from scratch yet.Dana on her I believe gets some from hobby king.
I am wet sanding. I findout u.don't dip the sabdpaper butbspray with a spray bottle then sand. Seems good. I donto really see a difference in wet and dry.
Would duct tape we put on last and is itblike duct tape material and thick or should I buy decal sheets from my lhs
So tomorrow I.plan on getting rid of the rest of the blue. Also do I need a primer since there is still paint? also should I add some expanding foam in the sponsors to strengthen the hull? I will possible start blueprinting Friday and continue Saturday. After that I have a camp at mizzou for wrestling but the next week I will paint the boat. I will resand AGAIN and clean. I am now wondering what my base coat will be if I choose to use that boat I chose to copy paint. Would the base be green with the blue on top then checkered flag?
