just wondering if this cable will work because the blackjack 29 flex cables are on back order until next month.
Will a proboat miss geico flex cable work for a blackjack 29?
Tags: None
OSE sells top notch upgrade cables, I have MG V1, I don't know if it's the exact same length, but you can measure the one you have now and determine: http://www.offshoreelectrics.com/pro...e-mystic-cableToo many boats, not enough time... -
I see, well, my feeling is that they should be the same length, but hopefully someone else who is SURE of the measurement will chime in to help, good luck!
In any case, I don't know which maker is the one on e Bay, but I can tell you for a few dollars more, the OSE ones are the best!Too many boats, not enough time...Comment
I got a miss geico one from kintecracing for my mystic, fits just fine!i would assume all the of these boats r the exact same thing!Comment
Just buy a Hughey .150" flkex shaft with a 3/16" stub and cut it to length. Youll have a much higher quality shaft, and its easy to do. Just remember to measure twice before you cut.
A stock BJ 29 flex shaft is 12.75" long from the tip to the threads on the stub. The stub has a length of 2-7/8"Comment
YES!!! The PB prop is made of steel, although they say it can be used, don't use it w/o balancing . It is heavy( steel) and any unbalance character will be amplified under high RPM thus wearing out your components quickly, especially the bushing in your strut!Too many boats, not enough time...Comment
You should have just gotten an octura, would have gotten u better performance and lighter material! :/
As to ur question, I agree with tlaunder, u should definently balance it!!!Comment
