*** NEW *** Pro Boat Veles 29 Catamaran
ARGHHHHHHHHHH! Wish I checked here an hour ago!
Maiden voyage. 20 feet from the dock - spinning motor, no go ..
Swim out to get her. What's missing here?
[ATTACH=CONFIG]153925[/ATTACH]
[ATTACH=CONFIG]153926[/ATTACH]
I don't recommend anyone running this thing until you get an updated shaft.
I'm really pissed right now.Vac-U-Tug Jr (13mph)Comment
There's too many reports coming in on this boat by people that know how to run a boat. There's has to be some manufacturing defect in the cable. I don't know what it is, but I wouldn't trust it! How frustrating is that, on a new boat!Comment
This is not a beginner boat. Most everyone who buys one has run FE's before, I would hope. I would still buy one, just be aware that your prop will most likely end up on the bottom until you get an updated shaft.Comment
So I am not the only one with a broken Veles crimped flex. Check out post # 86
twospeed, did yours break at the crimp or did the cable snap? Can you post a picture of the broken pieces or piece? I was lucky enough to find my prop. I had to wade around in 3 feet of water for a while before I found it. Yes, I was pissed off as well.Last edited by vinnyp; 09-22-2017, 09:38 PM.Comment
The prop and the other piece of the shaft are at the bottom of the lake in 10' of water...
shaft2.jpgComment
Two-speed
Looks like it came apart at the crimp, just like mine did. I would contact kfxguy and ask him if he can make you up a good flex. This crimped flex seems to be junk. At least yours moved 20 feet, mine made it about 2 feet under power.Comment
After inspecting the flex that was sent to me, I feel confident a crimped flex is not going to hold up to the power that stock motor has. It's capable of 70mph speeds, so it's putting down good power. Ehen the shaft was made they should have at least added a drop of retaining compound. At least it would have had a chance. I could be wrong but I'm suspecting the test units they used before production had soldered shafts. The crimp on the shaft I have is weak enough that when it pulled out, you couldn't even tell it was crimped down onto the flex32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) wasComment
