today was my first run with my sv27r. after 3 min running. i brought it in, and the amount of water in the hull is ridiculous theres heaps. what do i do??
First run today
Tags: None
The second thing to do is check the water cooling system.
The last thing is to focus on the drive shaft.
I have been running supervee's for a number of years and the usually the leaks you are describing are all the places where they have screws going through the hull.
Just drop in the the bath tub to ensure you have all of those type of leaks fixed.Last edited by electric; 08-13-2010, 01:13 PM. -
ok, thanks. i just charged up 2 batteries. off for a real drive. do i have to fully dischage the nimh bateries for them not to get memory??Comment
As far as I know, Nimh do not have memory effect like nicd batteries. With that being said when you see loss of performance in you boat bring it in.Comment
Try some of the CF props like a CF42 or CF45 (watch temps), they get on plane very quick, little less top end though then the stocker. Move to a 42x55 when your ready for a metal prop.Comment
the boats running ok. my only worys is the amount of water, and that it gets really unstable in the turns.Comment
Adjust the rudder negative, page 5, that should settle the transom down some and help stop hopping in the turnsComment
just had a drie then with glassy conditions. AMAZING. no water at all without hatch tape. hopefully its like this all day. how long do i have to wait after running to charge the batteries. i waited like 15 mins and they were still a bit warm. but i still charged them. my batteries also have a bit of moisture in the casing. is that bad. what do i need to know about nimh??Comment
Tape that hatch man, your asking for problems. One bad flip and the hatch is bye bye, and if your boat is upside with a blown hatch kiss it goodbye. I run the Kintec Racing upgrade latch with the foam. If you want to play the no hatch tape game at least upgrade the locking mechanism. Those stock push latchs suck. Like i siad man, your asking for a whole slew of problems running without taping that hatch.Comment
