New Custom Turn Fin.
  • rchippie
    • Jan 2010
    • 567
    #46
    Originally posted by m4a1usr
    The main reason for that is the right turn fin is closer to the rudder as well as the direction of the props rotation.
    John
    Thank's for the repily. Will large turn fins help the performance at all ?.
    • m4a1usr
      Fast Electric Addict
      • 2038
      #47
      Anything that hangs off the boat and down into the water will induce drag. So in theory you should only use turn fins if the boat doesnt control well. With that being said I put turn fins on all of my monos. Call it force of habit, whatever. They certainly are not needed on every hull. The idea behind turn fins is that they only get "wet" when you are turning. They are not needed in a straight line (unless you got bigger problems occurring) so keeping them out of the water when on plane is going to give you the most performance.
      Defining how big they should be in another consideration. Acting like a fixed rudder you dont want big monsters. I like the 22 to 25mm wide turn fins on smaller monos. In the 24 to 29" size. And 30 to 40mm on hulls up to 40". Havent owned a mono bigger then that so I dont have any experience. Remember the wider they are the greater the drag in a turn. Its possible they can act like a brake in tight turns. That can be a good thing or a bad one. Only playing around will determine that.
      John
      Change is the one Constant
