Nate, I ran that set motor/esc in my 26" delta force mono -> 4S and X645 = 43mph
I then stepped up and ran 6S on a carbon fiber 42mm prop = 50 mph. temps all < 120. motor was cold. I bet you could get 55mph on 6S and an X445 as long as you check temps. You might set the world record for fastest SV, who knows? You might need to add another pound of weight to keep it on the water.
I ran the boat today for the first time to get everything setup for the feigao12l and x438, Iv ran the proboat system in it with an x442...it seems to run around 38mph on the X442. Then I swapped to an x450 and ran right at Im going to guess 40-41. It was pretty fast..faster than stock SV for sure...
Iv been having alot of trouble adjusting that SM Stinger strut, its lowest setting is dead flat with the center of the hull...it needed to be lower...so I had to pull it off, then cut and bend the brass tubing lower...finally took it out again and put an M445 on that beast...
Its a rocket for sure...
Iv not had time to check speeds, but im thinking twice on using the Feigao motor...might be too fast for this boat lol
