flood chamber?
MODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
I got mine here. There are alot of other places too if you do a search. WillMany issues!!!Comment
http://stores.ebay.com/Elite-Motoring
Wow that aint cheap!Pro Boat Apache 24 Brushless, Thunder Cat 31
AquaCraft SV27, AqauCraft UL-1Comment
I got to thinking about this..instead of using the carbon fiber sheets to build a chamber...why couldnt you take a piece of 2" pvc pipe about 20" long and seal off one end..then take the sealed pipe and hold it against the outside of the transome and trace the 2" pipe and cut it out the slide the assembly into the new hole you cut with the sealed end first then just seal around the pipe at the transome end and then secure the pipe inside the hull with epoxy and some cloth
seems like this would work fine...if 2" pipe is to large maybe a 1 1/2" pipeSPRINT CAT 40.........BOOGIMAN 25" MONO 8xl
EX President of the Offshore FE Vultures SocietyComment
seems like this would work fine...if 2" pipe is to large maybe a 1 1/2" pipePro Boat Apache 24 Brushless, Thunder Cat 31
triangle PVC or ABS triangle tube and seal off front and glue to the back of the boat. The hole in the transom is more critcal to be able to fill faster when upside down.
Run a couple holes with silicone tubes out the side or top for air.
It should work on most v-hulls. The higher you can get it up to the deck the better.Comment
I was thinking the same with the silicone hose connected to the tube and out the top of the boat. I love this idea. I will get the square tube things from work and take some pics for yaPro Boat Apache 24 Brushless, Thunder Cat 31
seems like this would work fine...if 2" pipe is to large maybe a 1 1/2" pipeMany issues!!!Comment
Here is the vid!!!
Here is a Vid. The wife was busy so I filmed which Im not good at and dad drove which he isnt good at LOL.http://www.youtube.com/watch?v=lPn2N9IJVtQMany issues!!!Comment
I think Dad did a good job!!
DougMODEL BOAT RACER
IMPBA President
IMPBA 19887L CD
NAMBA 1169Comment
