I have a stock setup and want to run LIPOs. Which the better solution: installing an LVC into the stock esc or buying a new esc? I plan to run only 2S ~5000mah.
LVC or NEW ESC
Tags: None
JohnChange is the one Constant -
Stock supervee doesnt have a lipo cutoff. I bought the low voltage cutoff for the stock esc from kintek racing and had nothing but glitching issues with it. I ended up frying my esc later due to other issues and bought a turnigy/seaking 60A esc with lipo cutoff and programming ability on ebay for $50/shipped. I wish i had bought it before going the lipo cutoff route. It is a smoother running esc than stock with a higher amp rating,and lipo cutoff. I would buy one if I were you. Good luck! Switching to lipo from 8.4v nimh packs for me gained 6mph!!!Comment
I run the Lipo shield from kintec as well which is a dimension engineering lipo shield (also sold here on OSE) and I haven't had any problems. The stock esc doesn't provide low voltage protection for lipos and the lipo shield prevents each cell from being discharged below the recommened voltage. It's $19.99 or $35 pre-soldered with deans and beats buying a new esc. My stock esc is still kicking strong and with lipos its alot faster.Comment
I have to agree mine works great. Glitching can be caused by many things what radio are you using put up some photos I may be able to help or check out my photos. I use a Futaba 3PDF FM radio the receiver is inside the foam block on the starboard side of the boat let me know if I can help?2 SV 27's and Vac-U-Pickle UL-1 PowerComment
I'm not sure what was going on. Triple checked the wiring,but the power would blip on and off at low speed like a light switch. But at full throttle would be smooth. I read another thread somewhere where someone had issues with a slightly loose connection betreen the lipo shield and esc connection which caused the same issue. I am using a tactic 2.4ghz radio which I love. Gotta love lipo though. I fought it for a long time, but now I will nrver go back to nimh!!Comment
I'm not sure what was going on. Triple checked the wiring,but the power would blip on and off at low speed like a light switch. But at full throttle would be smooth. I read another thread somewhere where someone had issues with a slightly loose connection betreen the lipo shield and esc connection which caused the same issue. I am using a tactic 2.4ghz radio which I love. Gotta love lipo though. I fought it for a long time, but now I will nrver go back to nimh!!If all of your wishes are granted, many of your dreams will be destroyed!Comment
John
Change is the one ConstantComment
The ESC you are refering to is not the one that comes with a SV27 That one is for air planes get your self a LVC like this one http://www.offshoreelectrics.com/pro...hld-32&cat=136 or a new maybe this one http://www.offshoreelectrics.com/pro...=hef-sword-120
Good luck2 SV 27's and Vac-U-Pickle UL-1 PowerComment
Good luck
