oh, yeah sorry
Supervee rebuild
Autobailers and FE boats are not a good idea at all.
If you've got a leak, you need to fix that leak.
You want to eliminate any and all water inside the hull.
Whatever you do, do not resort to an Autobailer to fix your problems.Z
KBB34" Mono - Fast
ToySport Triton- Not as fastComment
I have, the boat is finished I only need an esc I am thinking the himodel 200a. I have been really busy lately between remodeling going on in my house and work I dont have much time or money to put in to it but it will be happening real soon. I will get some pics up soon of the finished boat.Comment
That supervee looks awesome. You do great work. I'm interested into buying a supervee as my next boat. Are you changing the esc because the stock aquacraft escs are normally junk or did it fry in the crash. When you hit 56mph what setup where you using?Comment
This is my progress so far, I've gotten more bits and pieces together and I'll order the speed control tomorrow. Hopefully I can get it back in the water soon and I would like to see 60 mph out of it. We'll see.Comment
looks really good man! i like how everything is spread out among the hull it will make it alot easier to work onA common mistake that people make when trying to design something completely foolproof was to underestimate the ingenuity of complete fools. -Douglas AdamsComment
Finally got something going on here. The set up I will be running is a 10xl,Etti 150 running on 2x Zippy 5000mah 40c 3s.I actually got to run it today but by the time I was ready with the boat the sun was already going down so I didn't have time to tweak it any .It rode like crap I need to adjust the stinger the bow was bouncing really badly I could not get over half throttle but I did throw the gps in it and even with all of the hopping the gps showed 36 mph ,under half throttle, so I think I should get some pretty good speeds from this one as soon as the bouncing is calmed.Comment
Looks pretty awesome mate, I really need to start thinking about this sort of rebuild cause shes falling apart. So you guys polish the bastards hey? I spose it helps them slip through the drink better? My sv has damaged ribs,rear corners,cowl the nose has hit a limestone wall when the radio failed one time and the motor mount plate is bent. i bought a fiber glass repair kit but i've never done it before so do you's reckon from what i've said its fixable or should I just get a new hull?Comment
finally got something going on here. The set up i will be running is a 10xl,etti 150 running on 2x zippy 5000mah 40c 3s.i actually got to run it today but by the time i was ready with the boat the sun was already going down so i didn't have time to tweak it any .it rode like crap i need to adjust the stinger the bow was bouncing really badly i could not get over half throttle but i did throw the gps in it and even with all of the hopping the gps showed 36 mph ,under half throttle, so i think i should get some pretty good speeds from this one as soon as the bouncing is calmed.Comment
