gutted motley crew
  • Treeman724
    • Feb 2013
    • 179
    gutted motley crew
    I wasn't gonna do this until the race season ended but I had a guys sponson punch a hole in the side of my boat and decided it was time to do this. I cut out the tub and went through it properly. Wow, what a difference it made, this went from a sport boat to a full on race boat. I can easily outrun any other cat in the class including four other mean machines.
  • siberianhusky
    • Dec 2009
    • 2187
    How much flex does the deck have now that you have removed the tub? When I did the last rebuild of mine I thought about doing this but was worried that it would fall apart or cave in during a blow over! Not exactly the thickest layup for these hulls.
    Looks good, I installed some wooden rails in mine and ditched the stock motor mount, also moved the motor towards the back of the hull, made a huge difference, more room to move the batteries now to dial in the CG, also made the bottom of the tub a lot stiffer.
    Also swapped in a SV27 rudder with watercooling, I run both pickups and cool the motor and esc separately, ran the new line in the old exit, installed two outlets in the side of the hull so I can see the water exiting.
    Fun boats once you get them dialed in.
    Oh ya also put a layer of 'glass on the inside of the hatch, replaced the plastic braces with some carbon fibre rod.
    • Treeman724
      • Feb 2013
      • 179
      I like the idea of the sv27 rudder, I also move the cooling exit to the side. I didn't no tice a significant loss in rigidity after the tub was out, I've endowed it multiple times since I went through it and its still here.
