So I?ve been following the bj 42 since released. I?m very interested in buying but the whole flipping under wot no matter the setup is very depressing to see. The only ones that seem to keep the boat in the water at high speeds are running lifting prop. Would anyone have a good suggestion on which prop would be good to start with? I?m about to order the boat and a prop just don?t quit know which to go with. Any help for this boating noob would be highly appreciated. Thanks in advance guys.
Proboat blackjack 42 prop suggestions
No, not all props are lifting. De-tounged are non lifting and all kinds of other options out there. Different nomenclature for different manufacturers but they typically list de-tongued.
https://www.offshoreelectrics.com/pr...Tongued+SeriesComment
they not detongued just standard cnc prop ,i am supriced how much lift these props give ,i have 2 MHZ cats and a sprint cat and they don't like cnc prop i use on these cats Prather or ABC props but what i see on youtube a blackjack a cnc prop can help you have to find out about the diameter of the prop (maybe 48mm or 50mm??)Comment
