props????
  • launchpad
    • 194
    props????
    I am building a genesis boat.Need info on props.It has 2-leopard 3674 motors;2- turnigy 180.I will be trying the amount of cells on each.Starting with 3 cell batts then progressing up to 6.Could someone suggest what prop to what will s I can use with the twin combo.This is my first build of a cat with twins.
    Any suggestions would be great.
  • tlandauer
    • 5660
    From 3s to 6s is a wide margin, your motors would have to be fast enough for 3s and don't get burned with 6s. What kv?
    Such a margin it is hard to give a specific size of props.
    • launchpad
      • 194
      Hello;
      Sorry for not informing of that. They are 2200kv thanks
        • 7651
        I think a pair of CR CNC 442's or 642's would be a good pic for you. I assume you will just be working out the bugs on 3s. It's gonna be slow. Will you be running 4-5s? If so a pair of 45mm props would be good in that range.
        BTW, CNC are not optimum but with that range they are my safest suggestion for the amp draw on 6s.
        • egneg
          • 4664
          I suggest a pair detongued X442's.
          IMPBA 20481S D-12
          • launchpad
            • 194
            2200kv
            • Make-a-Wake
              FE Rules!
              • 5554
              I wouldnt go above 5s, 4s is plenty and will be quite fast. A pair of counter rotating x447's would get you moving out on 4s, 442's for 5s.
              • launchpad
                • 194
                thanks guys for all the info;i now have to consider all the options then try one.will keep trying different combos.goal is to get 60 miles an hour. I have set 4074 leopards I will try.does anyone know anything about the turnigy 180;with extra capacitor bank.
                again thanks
                • Make-a-Wake
                  FE Rules!
                  • 5554
                  Just realize that every prop suggestion given was with the 3674 2200kv's...................you have 4074's of unknown kv in the picture now..........
                    • 7651
                    again thanks
                    What would you like to know? They are good, strong, handle 6s well with BEC disconnected and have an LVC issue which is an easy fix.
                    • dasboata
                      • Dec 2010
                      • 3152
                      What ever you decide I can help you with a race prepped set of props thanks chris
                      • RCBoaterGuy
                        • Dec 2014
                        • 203
                        Yes he most certainly can!!
                        Chris,
                        Received mine today - GREAT JOB!!
                        Now that's how they're supposed to look
                        I knew those bozo's in California screwed me over (thank God for PayPal), you just proved it.
                        That's was my first order, but it most certainly will not be my last.
                        Keep up the good work!
                        AQ MiniMono - CopterX 430XL 3550kv BL Outrunner + Seaking(V2) 35A on 2S VERY Fast
                        Pro Boat SW26v3 - 2860-2600kv + Seaking(V2) 90A on 3S, Build in Progress
                        Pro Boat Stealthwake 23 - Stock For Now - Brushless Down The Road
                        • launchpad
                          • 194
                          props
                          Sorry about that;the motors I am using are 3674-2200kv.I mentioned the 4074 because I have 2 that are 4074.Hope this clarifies the sizes.
                          • Make-a-Wake
                            FE Rules!
                            • 5554
                            and the 3674's a more than sufficient to get that boat haulin butt
                            • launchpad
                              • 194
                              Thanks for the info.........
