Only put around 5 packs through the boat so far so still early days, This is my usual $12 3800kv outrunner & $20 esc. Once boat is ironed out ill fit a 4400kv inrunner on 3s, Like i said in a previous post if your going to use 3s fit a metal rudder bracket & not the wooden one as it wont stand the extra loads in a turn. Martin.
JAE Mini Sprint up & running
The boat has run faster with a x632 & esc PWM at 16khz,In this vid its a x435 so less pitch & PWM turned down to 8khz. Esc i get from www.giantcod.co.uk & is their 60amp cheapo one (theirs lots of these type of esc in diff amps all over Ebay which are the same esc with several diff names.Lipo is Overlander 3s 2200mah 60c-80c (again UK company). Motor is Mystery 2836 3800kv outrunner.Comment
I knew it would be, but that is a LOT faster than mine it really is rocking. Was that a full run battery full to empty in 45seconds in the second video?
If you were running on a laid out oval course it would massively lower the load on your rudder those tight hairpin turns are huge Gs.Paul Upton-Taylor, Greased Weasel Racing.Comment
Paul im looking at using a Leopard 2850/4430kv on 3s or possibly HET 1w-30 4400kv but thats in the future,Also thinking of shortening the rudder around 6mm for less drag.That night the vid was shot we done 3 runs that were recorded & total run time was for all 3 runs 2 min 25sec in total & i put 1717mah back in a 2200mah pack. The Overlander 60c are fantastic. The 1.2mm wire drive & 3mm stub running in 2 ball bearings i made is working very well with so little friction & is very reliable up to now with no water going in the boat at all up the tube. Martin.Comment
Getting some probs with boom tubes not being strong enough with the loads going through them, The original 3/16" hollow ones snapped first time out with just the lightest touch against the bank. Changed them for 5mm solid carbon & also changed the brass tube that went through the tub to bigger carbon tube so i could use the 5mm solid going through them (3/16" is impossible to get in the UK so went to metric). Even with 5mm solid carbon im getting a crack in the carbon where the 3/32" hole is drilled through that bolts the sponson on to the boom tube, This is the one where the fin is so its the turning loads thats cracking it.Im either looking at not bolting through the boom tubes & using collars or going up to 6mm solid carbon,Either way i wont bolt through the carbon again. MartinComment
Looks kiler man!
not sure I would need the higher kv motor, that thing ripps...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Things are never to fast,With the outrunners youll limited to how fast you can push because of their generally lower kv however you can gain speeds over some inrunners because of the extra torque of the outrunner taking bigger props but you are increasing temps. Im using Octura x435 detongued & back cut in the vids & have run faster on simular mod x632. Im going to 4400kv inrunners on modded Octura 1630 prop which i believe will be much faster.Comment
About a week or so after these vids were shot i was out testing & had a steering problem & at WOT went head on into the concrete bank. So am rebuilding, Quite extensive damage but rebuildable. Even the lipo which was strapped down shot foward into the rear boom tube where it goes through the tub & pushed the tube foward 1/2" splitting the tub side which in turn put a large impression of the tube in the end of the lipo rendering it no good as it was shorting out & getting hotter 20 minuites after unplugging. Still it did hit hard.Comment
Can you post up pic's of your drive system with the ball bearings?Paul im looking at using a Leopard 2850/4430kv on 3s or possibly HET 1w-30 4400kv but thats in the future,Also thinking of shortening the rudder around 6mm for less drag.That night the vid was shot we done 3 runs that were recorded & total run time was for all 3 runs 2 min 25sec in total & i put 1717mah back in a 2200mah pack. The Overlander 60c are fantastic. The 1.2mm wire drive & 3mm stub running in 2 ball bearings i made is working very well with so little friction & is very reliable up to now with no water going in the boat at all up the tube. Martin.
Thanks,
-GaryComment
The flex one is .130" with a 4mm stub, the wire drive is 1.2mm ( .048") with 3mm stub. Both o/d of the bearings are the same diam so both types fit in the same tubeComment
Thanks Martin! So the whole assemble slides into the stuffing tube? I take the collet is what holds everything in place? What type of bearings did you use? Learning as I go, so thanks for the feedback. I'm sure someone else will benefit from the info and pic's.[ATTACH=CONFIG]88271[/ATTACH][ATTACH=CONFIG]88272[/ATTACH][ATTACH=CONFIG]88273[/ATTACH][ATTACH=CONFIG]88274[/ATTACH][ATTACH=CONFIG]88275[/ATTACH]
Yes it all slides in & when removing to clean & regrease the whole lot comes out to make cleaning & drying the bearings easy,the alloy tube is separate to the brass stuffing tube so the assembly only goes so far & hits a stop inside the tube. The collet holds it in place, ball bearings are 3mm i/d x 7mm o/d or 4mm i/d x 7mm o/d.Comment
What do you use for a stop in the stuffing tube and what size is the stuffing tube? Also, In the pics you have the bearings 2 in the rear in one set of pics and 2 bearings in the front. Does it matter?
Thanks,
-GaryLast edited by Gary Mullens; 11-09-2012, 04:34 PM.Comment
