So close!...Help
  • greatlakestate
    • 38
    So close!...Help
    I tested out my project 30" Prather Commander w/ 700 motor K&B outboard conversion today and it ran solid. I don't expect to break any speed records, but it is a fun boat...quick to plane, rides smooth turns on a dime
    I quickly discovered an issue with the transmitter/ receiver range. Until I upgrade, I am using an old Futaba 2 channel that has worked perfect for me since new in the 90s. It had a frayed antenna wire and I decided to replace it. I took the receiver to an electrical shop and they matched me up with the correct wire. I spliced and soldered it in to the original undamaged portion of the wire about 3" from the hole and used heat shrink to seal. I have about 20" antenna total, maybe 16" exposed in a tube outside of the boat. My range seems to only be in the 10-20' range, after that it cuts out. I experimented on shore, same thing fine at close range, acts jittery and finally cuts out after 20 feet or so. I added about 3" of extra wire and taped it upright with the boat on the garage workbench and it worked flawlessly, I walked outside and was at least 100' away. I tried it with the wire just hanging over the boat and got the same short range issues. I am using a Jeti 600n and have a receiver battery pack. All batteries are brand new, connections clean and tight, and everything has been checked and re-checked.
    I am wondering if I did something to affect the range when I replaced the wire? Maybe I should solder directly to the reciever board and replace the entire wire? Heavier gauge?...I'm clueless. I have come so far, hopefully this is an easy fix, but I know almost 4' of wire wipping off my boat won't do!
    Thanks for the help ----Rob
  • bustitup
    • Aug 2008
    • 3071
    I'm pretty sure standard length of 27 MHz antenna wire is 24" and its kind of critical that your close to exact because this is how you get the frequency needed
    • paulwilliams
      • May 2007
      • 82
      Have you fitted suppression capacitors and a schottky diode to the 700 motor?
      Paul
      www.fastelectrics.net
      • alvinsmith75
        • Jul 2008
        • 635
        Antenna should be unsoldered from the circuit board in the receiver case and a whole new one attached at the factory length.
        • crabstick
          • Jul 2008
          • 954
          yep, you should never join or splice the Antenna wire, always solder a new one and i think 24 inch was about right for 27-29mhz if i recall correctly
          Matt.
          FE, Nitro and Gas racing in Auckland
          www.rcboats.co.nz
