Is my rudder too small ? Rudder size for home built 24" wildthing mono hull
  • synrgy
    • Sep 2012
    • 5
    Just checking if my rudder is too small ?
    The boat is scaled down wildthing - 24"
    Its a 62mm long rudder & comes back 63mm from the transom. I feel it looks a little small to other mono builds I've seen. Also am I mounting it too low where it is now ?
    It's my first larger size boat, ive only had toy grade before...
    Thanks all
    Dave
  • dasboata
    • Dec 2010
    • 3152
    that looks fine all you need is 1"-1/2" below the tip of the prop , you will know if it's to short if it spins out in the turns !
    • NativePaul
      Greased Weasel
      • 2761
      Yes, that rudder is more suited for boats about 18".
      If you want to keep it cheap, use one of the generic Chinese 75mm rudders.
      • jkflow
        • Aug 2021
        • 329
        Suggest to add some turning fins.
        • synrgy
          • Sep 2012
          • 5
          Thanks all - I managed to find the original designers article of the 32" nitro wildthing & hes got the lengths there. So looks like im a bit short on the rudder, i'll get a new one.
          Also has measurments for turn fins..
          I figure at 32" mine would be 75% so ill reduce those measurements down to 75%.
